235
Everything posted by Loyale 2.7 Turbo
Cars compatible with 89 GL-10 Turbo
Loyale 2.7 Turbo replied to DSwanson1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Seems like maybe it will be Easier to find another car... a Donor to swap parts. -
New Find 89 GL wagon
The Rear Differential has a Sticker that says: LSD and the Ratio. Kind Regards. -
What I wanted to say, is that you must be more specific, because few parts from other cars will "Bolt-On" your Subie, I know about certain coil Springs, and Calipers / brake pads... but we need to Know what do you need, first. Kind Regards. -
What parts are you Looking for? -
Thank you, I was unsure because Automatic EA82's are super Rare and Scarce in Honduras. My wife's Car has those lights, but isn't a Subaru... Limited Slip Differentials exist in Subarus since the Second Gen Leone / EA81 era, but also they are not very common, the very first Subaru LSD has 9/35 combination, to give a 3.889 LSD, which then was rounded as 3.9 ... you can read information from an example, of another USMB member who has an EA81 with factory 3.889 LSD differentials, here: ~► http://www.ultimatesubaru.org/forum/topic/109465-84-4wd-wagon-new-daily-driver-with-future-ej-swap/ Kind Regards. -
Those who continue using Adobe Reader, are those who has Not discovered Foxit Reader, which outperforms adobe being more than 10X faster and lighter, being fully compatible with Web Browsers, and Free! ~► http://www.foxitsoftware.com/downloads/ Kind Regards.
Rebuilt EA82, low oil pressure and ticking.
Loyale 2.7 Turbo replied to djellum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your Local Subaru Dealer might have them NOS, and at a Reasonable price. Kind Regards. -
I can not see very clear this image. Since not all the instrument clusters are equal, Let me ask you about the Green Squared Light, in the Middle / Up, seen here: ... ... What does it Says / belongs to? Kind Regards. -
No, there are very Respectable enterprises that offers Free Versions from their Software. Of course, their free versions have some Limitations, but tend to be more than enough for the normal Home usage. In example, Avast and Avira gives a Free version from their antiviruses, which sometimes outperforms their similar but Paid counterparts; in fact those antiviruses has many years to be in the Business... Also Piriform gives three of their great softwares for free, one is CCleaner (Crap Cleaner), that removes unused files from the Windows' systems, plus cleans system keys and much more features, the other is Speccy, which is a Tool that says the real "Truth" about any computer's Hardware, also there is a free version of Recuva that recovers erased photos and files from any media... Kind Regards.
Since the rusty lug Nuts that came along the Hyundai Steel Rims I have, are designed to hold Hub Caps (I dislike Hub Caps so I didn't put them) ... ...their wide flat washers doesn't allow them to fit on the Aluminium Wheels, so I had to search for new lug Nuts that fits good on the... ...Aluminium wheel's Base, shown above. I found this ones which are Strong and well built: ...which seems to fit well, but has an elongated curvy base, that is not going deeply inside the 45º portion of the seats. What do you think about that?
While I have the time to do the Paintings, I've been gathering the other needed parts, to instal those wheels on my "BumbleBeast" such as the full metal schrader valves
Dumb speaker question
Loyale 2.7 Turbo replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Because the Software you're using on your Desktop to view the images, Has the Auto-Rotate feature, to correct the Photo's Orientation. Kind Regards. -
I know this is off-topic, but This: Really looks like a Disease, somehow... Kind Regards. -
Speakers that Fit, and wire them Properly: The Positive to the + and negative to the - Otherwise they will sound, but working Backwards. Usually any Speaker rated between 4 and 8 ohms is Good, And wattage between 25 and 50 R.M.S. will be Enough. Kind Regards. -
Usually old ones Flattens by usage. Motor Oil with Too high Viscosity number and Wrong Oil Filter. Kind Regards. -
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
From that place, you can see on the Mountain Top, Far Away... ...These Windmills that generates Electricity in Honduras. -
Kia Sephia Sporty
This photos were taken by me, on an ancient part of the Capital Citie's Downtown, which has several steep hills, so maybe it should be called Uptown instead? -
Kia Sephia Sporty
Better Understanding the Situation Want to know the reason Why, when the engine Cooled overnight, it Seemed to start normally, and only Failed at Normal operating Temperatures? The engine's ECU has a different fuel / air mixture settings for Cold Starts, that recreates the function of the "Choke" found on Carburetors; so the engine start easier; then the ECU reset those settings back to normal, once the engine reaches normal operating temperatures. That perfectly explains why it always started at the first try while it was Cold, then failed at Normal Operating Temperatures: That was the failing check valve's behaviour. Everything has been resolved with the whole Fuel Pump's assembly change. Kind Regards. -
Thank you for your kind advice. Yes, somehow that is what I obtained at "Sur" paintings: the Aluminium Primer and then, an industrial Grade, Black Paint, chemically designed to withstand the requirements of Heavy Machinery, so the paint will be much more chip resistant, than the average paint. Now I need to find the proper time to do such paintings... I'll borrow an air compressor & hardware from a friend. Kind Regards.
