236
Everything posted by Loyale 2.7 Turbo
Switch to Left of Steering Wheel
Loyale 2.7 Turbo replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, ABS means the Kind of Plastic that was used then, ABS Plastics can last forever on a Car, it is Shame the Pollution Prevention Regulations, require that cars are made with Biodegradable plastics, that is the reason why many wirings' plugs disintegrate and does all kind of wrong things to the cars nowadays... The space about he is writing about, is the one used for the Manual Choke Lever, on the 1.3L (EA65) and 1.6L (EA71) Loyales, yes, I placed the Rocker switch for the Halogens on my "BumbleBeast" in that mere place. Kind Regards. -
A year in review
Loyale 2.7 Turbo replied to Adam N.D.J.'s topic in BRZ and its Sister the Scion FRS/Toyota GT86
I really Like those two of Statements. Also I really Like the Photo above, of Both coupes Together. Another year has passed by Already. Any news with your BRZ? Kind Regards. -
Fuel filters beware
Loyale 2.7 Turbo replied to tweety's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, seems like Water / Condensation on your Fuel Tank. Maybe it is time to check it, its Ventilation & Connections... Kind Regards. -
Dear Thomas, Maybe you're interested in this Euro Style NOS Tail Lights? ~► http://www.ebay.com/itm/NOS-1980s-Subaru-L-Series-Leone-Loyale-Station-Wagon-Van-Estate-rear-lamp-units-/291455117102 Kind Regards.
Subaru Ambassador?
Loyale 2.7 Turbo replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
Today, a gift package arrived for me, sent to Honduras by my Friend, MilesFox: So, I have a couple of items of the Ambassador program! Also a new part for my "BumbleBeast" shifter linkage, Thank you so Much, MilesFox. Kind Regards. -
Yes, only you can turn such an Awesome Car, into an even More Awesome Car! Right now, I like it very much, kinda remembers my "BumbleBeast" paint scheme. Kind Regards.
Thank you, I'll search among local stores to see if I could obtain such "Aluminium Primer" rattle can of Rustoleum, here. Kind Regards.
Important Note: Not all the third gen Leone lineup, had background illumination on the above written Buttons. It depend on the Year Model and trim level. Kind Regards.
- 190 replies
- 1
- Instrument
- Cluster
(and 7 more)
Tagged with:
My plan is to Complete the LED bulbs' Retrofitting, on the Switches that has T3 bulbs. On the EA82 \ Third gen Leone / Loyale, the Power Mirrors' Switch, the Rear Gate Lock's Switch, the Rear Wiper's Switch, the Cruise Control Button on the Upper Dash, the Height Control Button, the Fog Lights' Button, etc... has a T3 incandescent bulb built-in, which Soon I'll be swapping with LEDs T3 "Neo-Wedge" and, as I pointed in Previous posts, those T3 LEDs can be used on the instrument cluster's Centerpiece, instead the incandescent Bulbs. Kind Regards.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Also, along those LEDs, I received some T3 "Neo-Wedge" LEDs with built-in Resistor: I placed one of those, next to a couple of Honduran coins, to give the size's idea. Those were Purchased here: ~► http://www.ebay.com/itm/10x-White-Neo-Wedge-1-SMD-1210-LED-Car-Bulbs-T3-HVAC-Climate-Control-Lights-N001-/311210929800
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
I just received those LEDs yesterday, purchased here: ~► http://www.ebay.com/itm/700LM-2-x-1156-BA15S-Samsung-SMD-5730-Car-LED-Warm-White-Tail-Signal-Light-Lamp-/221412913653
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Continuing with the LED lights' Subject, Long years ago, I swapped the Front corner lights on my "BumbleBeast" From incandescent 1156 Bulbs, to "Super Bright" leds, with 28 led tips on each one ... ...as you can see in this old post: Now, despite that those 28 Led's 1156 bulbs are still in good working order; I wanted to send 'em to the Reverse Lights' lamps, and upgrade the Fronts with This:
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Yes I completely understand. But what I meant, was that you can Remove the T3 LED Bulbs that already comes with built-in protective resistor, from their "Neo-Wedge" rubber base, by unwrapping their twisted legs, and then wrap those legs again, onto the Subaru's centerpiece Rubber bases: Voilá! Perfect Fitting. Kind Regards.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
EA81 Dyno Tune results
One word: Awesome! Yes, at ~ 9.48 Compression ratio, that EA81 must be in the Neighbourhood of 100 Hp at the Flywheel, and I Agree with you, many people spend their money in Expensive cruisers that doesnt payback a single drop of Fun. Thank you for sharing this information and Photos. Kind Regards. -
Maybe those "Rubber mounts that has small lamps stuffed into them" could be swapped with T3 "Neo Wedge" LEDs. Some of the Dashboard's Buttons, such like the Power Mirrors, Rear Gate and Rear Wiper, comes with T3 incandescent bulbs, inside the switches. (not all models featured background illumination on the Buttons) Also some of the Upper dash buttons, such like Height Control, Cruise Control, etc, comes with a T3 stuffed inside the Button's structure, so they could Lit whenever the button is Pressed, despite if the Background illumination, (provided by a lateral, independent T-5 bulb), is on or off. Kind Regards.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
Yes, I agree with you, however, since those wheels are made of Aluminium, the Rattle can will need a primer suitable for aluminium, and that will raise the cost, also such primer is not easy to find locally, in the form of a Rattle Can, because I've never seen such a thing locally, so far... By "2-pack" paints, you refer to the Primer + Paint, isn't it? Yep, those are Easy to find in local Aftermarket parts' stores and Hardware Stores, such like Doit Center, or MegaLarach, but I've never seen a Primer for Aluminium on a Rattle Can, yet... maybe I better gonna search and Ask them. Kind Regards.
Dumb Question? Loyale vs. GL (Wagons)?
Loyale 2.7 Turbo replied to DT250a's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those mini Subaru Rex / Fiory \ Vicky also were sold here, in Latin America. I've seen few in Honduras, LHD... Click here for Photos of a "Vicky II" edition: ~► http://www.ultimatesubaru.org/forum/topic/50983-strange-and-weird-subaru-stuff/page-73?do=findComment&comment=1202072 ... but we have pretty same reasons like Australia, to prefer Bigger cars, Kind Regards. -
What I've done to my Subie, Lately? ... This: These are the Blank mini center Caps and the Silicone Stickers as they came on the Mail: This is one of the Blank mini center caps, it has emblazoned the Measurements: I tested them on the Nissan Wheels: The Blank Mini Center caps, fits Perfectly!!! Here I am glueing the Silicone Subaru Logo to the Blank mini center Cap: This are the Results: Absolutely Perfect Fitment!!!
Great Job you've done to your Subaru, engine bay looks Clean! I'm glad that you live far away from the horrid Traffic Jams and Steep hills we have in my Country, Otherwise your Knee would not be that happy... Kind Regards.
I'm really Glad that you received the Black RX handle, Thank you for sharing the Photos! Kind Regards.
The Trike is Awesome, and also your EA81 looks Awesome. Very kindly, Let me ask you: ~ 53.2 Hp on the Wheels, Means how much Total Hp output from your Modified EA81? Kind Regards. -
You did a great Job, removing the Tint from the Background: Thank you for Sharing the Photos!!! Kind Regards.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
