2
Everything posted by msmithmmx
Here is how I rebuilt mine. http://www.ultimatesubaru.org/forum/topic/162275-knuckle-rebuild-after-ball-joint-pinch-bolt-snapped/?fromsearch=1
- 46 replies
- knuckle
- snapped bolt
(and 4 more)
Tagged with:
Take the nut off the ball joint flip it over and screw back on a little. Take a floor jack and place it under that nut. Jack it up a little until you see the control arm move up. Go to Lowes and get a 3 foot pipe used for natural gas applications. Direct the pipe on the control arm and just keep hitting it downwards with a hand held sledge hammer. This may go on for 30 minutes until you see it drop off the ball joint.
- 46 replies
- 1
- knuckle
- snapped bolt
(and 4 more)
Tagged with:
Please take lmdew up on the offer. I wish I did a year ago before I got involved in the same situation your in now.
- 46 replies
- knuckle
- snapped bolt
(and 4 more)
Tagged with:
Your not the first. Try getting the engine up to operating temp and try to twist both directions. This guy used a dremmel and cut it out and that still did not work. https://forums.vwvortex.com/showthread.php?5735677-36-mm-socket-cracked-then-disintegrated-my-oil-filter-housing#/topics/5735677?page=1
I suspect 2 things went wrong in the tail housing of your transmission. 1) The clutch basket has sheered off of the input shaft. 2) Duty C solenoid has failed. There is a special process to pull the code from the blinking AT lights. A scanner will not do the job. Search around for the handshake process. Below is a link for this type of problem. To have a pro do this job will be at least $1,400. https://www.ultimatesubaru.org/forum/topic/121116-at-light-flashes-16-times-what-to-do/?tab=comments#comment-1021625
Why do you need a knuckle? Is it cracked or warped? Your talking about a 20 year old part that takes a beating every time the car is driven. A used knuckle should cost $70 shipped off ebay. Expect to rebuild the entire knuckle. Bearing/seals/ball joint/hub. The additional new parts will cost another $70. Rebuild of the knuckle is one hour shop time.
Good post. Sorry if I missed it. Why did you cut the sleeve out when you can buy the entire unit already pressed?
- 5 replies
- control arm
- bushing
(and 3 more)
Tagged with:
Hello. Before you purchase any parts get a $35 gauge set off Amazon. What are your low and high side readings at idle and 2000 RPM capture the temp outside when you take those readings. The temp sensor is clipped on the evaporator. Sounds like your high side is low. https://www.amazon.com/OrionMotorTech-Diagnostic-Manifold-Refrigerants-Couplers/dp/B019W5LIVS/ref=sr_1_1?ie=UTF8&qid=1532266465&sr=8-1&keywords=ac+guages+r134a&dpID=51p6DTOqCiL&preST=_SY300_QL70_&dpSrc=srch
Hello all. 98 OBW 250K 2.2. Noticed the Front driver control arm rear bushing is leaking. I can buy the bushing for $23. Looks easy enough to swap. After 20 years on the salt filled roads of PA should I expect it to be rust welded in place and should I just replace the control arm? Can it really just be unbolted with control arm left on car? Link to the part below https://www.ebay.com/itm/Rear-Bushing-Left-Front-Lower-Control-Arm-Hydro-FEBEST-SAB-001L-OEM-20201-AC110/222331100045?epid=210174452&hash=item33c3f75b8d%3Ag%3AIdIAAOSwC-taHu~g&_sacat=0&_nkw=sab-001l&_from=R40&rt=nc&_trksid=m570.l1313
- 5 replies
- control arm
- bushing
(and 3 more)
Tagged with:
