				Posts836
				Days Won2
Everything posted by msmithmmx
	DEKS69. First, it sounds like you have a busted HG, but you should have your coolent tested for HC's. I also would go to the dealer and purchase the $1.98 4oz coolant conditioner. Its worth a try. I do not think you can just put in the 2.2 Turbo. You will need at least an upgraded fuel pump and I would guess other electronics.
	It went to the dealer because it felt like the engine was missing. They replaced the coil pack to fix (400 bucks). While it was there they read the codes and it had a low reading from cat1 and a knock sensor code. Thats when the pile on started. I am calling the dealer about the HG, my guess is they did the recall (add coolant conditioner) and now want do the HG while they are replacing the rocker cover gasket. Thats where I came in and stopped the madness. I see how this could be painfull for some when your facing 2G's in repair. I gave my brother my 97 black OBW while I attack each issue. Question!!! There are 3 good dripping points from the bottom of the engine Question!!! Will a 98-99 forester Cats fit a 00 OBW. I am thinking yes. Also could the headgasket seal drip oil and still not have any type of overheating problems?
	My brother dropped of his 2000 OBW 136K this AM at my house. Dealer said he has a busted HG and is also leaking oil from the where the engine meets the transmission. They also said his trans is bad and his cats are on the way out. NOW, I put that all aside and will diagnose each problem. 1) They said its not the oil separator plate and that it is bone dry!! Is there anyway to verify this without pulling the trans or the engine? How could they say this? There is just no way to see it. That is why I will need to verify everything they have said. This is the first 2000 I have ever worked on. One thing I noticed is this 2.5 only has 2 cams... I have only worked on 95 to 99. Any recomendations to troubleshoot bad cats?
	I want the 10 minutes back I spent reading that article. I see the point but its only 10 PSI for a brake system thats 10 years old. It was under pressure for 15 minutes tops. The fluid that came out was the color of dirty motor oil. When I was done I did not have any air in the sytem. I must add the brakes are much better now
	The OEM belts typically line up but its not a fact. The most important thing is the arrors on the crank and cam pully are pointing in the correct direction. Also that you have the correct tooth count between the crank and left and right cam pullys. I want to to say it's 44 1/2 on the left side and 40 on the right side. I amost made the mark mistake until I counted the teeth. COUNT THE TEETH
	The specifics, 97 OBW 2.2 with 180K. Here is my problem and it happens when it is REALLY cold outside (32 and below). The brake pedal at startup is very stiff, and will not stop the car. That goes on for 3-4 seconds then goes away never to return. If I let the car warm up for a few minutes then drive I have no issues. What I did::: The fluid was bad off, looked like used motor oil. I flushed the system, I used the motive pump I just purchased what a great job. That helped somewhat, now it has to be 20 degrees for it to happen. Am I loosing boost? Could I have a leak in the booster? Seems like its not charging at startup?. Generally the pedal is somewhat stiff but at start up it does not budge. I did a engine swap recently and I do not know if I had the problem before as I never drove the car with the 2.5 in it. I have another sub I did the sam swap on with no issues. Any thoughts. There is a 99 Forester at the local bone yard so parts will be cheap if I need them.
