2
Everything posted by msmithmmx
Its all done I also replaced the rear O2 sensor. Total cost of mid pipe and O2 sensor with new gaskets and bolts 280.00. I hope I saved some money, Does any one know what it would have cost? I do have some leakage at that flex joint, The book said 14lbs on the bolt. I am going to give it a day to settle in. I will report back
I went to NAPA an purchased the exhaust Mid Pipe for my 98 OBW. I took my sawzaw to the exhaust and removed it finally.. I pulled the original busted exhaust out and layed it next to the replacement from NAPA, they are a little different. Question, will this work? or do I have the wrong part. I was just at the dealer and they have both pics in their system but could not tell me if they were interchangeable
Regarding the engine replacement, on this forum some of us do them ourselves so the cost is low, total job might cost 300 to 500 dollars for parts. If you have shop do it your looking at 1500 for the motor and 1000 dollars in labor would be mu guess. I would not go with a 2.5 replacement I would use the 2.2.
From what you are describing you have a blown head gasket. I am 99% sure of this, as stated before you need one test to confirm this. Have the shop test the coolant for hydro-carbons. There are cases where a compression test will not catch a VERY slow head gasket leak so do not pay 200 bucks for one and have them tell you they found nothing so it must be your radiator and 600 bucks later it is still broke. DON"T DO IT. The question for you, do you want to sink to 2 G's into this car? I would swap the engine for a 2.2. With a busted head gasket the car is worth 700 to 800. Just the truth here
I have a 98 OBW with a cracked exhaust mid pipe. I thought I would save a few bucks and swap myself. The bolts that connect the mid-pipe to the front section are completely rust-welded/deformed. Can I just take my Dewalt sawzaw to the middle and cut right through the bolts or is there some type of spacer there because I do not see any threads.
