2
Everything posted by msmithmmx
OK OK, Fixed. I installed a Used OEM Coolant Temp Sensor and now the fan roars on when its at temp. Turning on the AC does not engage the fan nor does the clutch come on. I am calling this a seperate issue. I hate lending my tools out because I do not have my ac test guages. Thanks to all that have helped me.
I had a very long post going before but I have decided to start over and summarize it. HELP ME The Car: I have a 97 Legacy 2.5 180K miles that is overheating when I bought it. It did have a check engine light for a speed sensor The Problem: The radiator fans will not come on. They will not turn on when the engine is at temp and it will not turn on when the AC is turned on How to force them on: I do one at a time 1) Disconnect the middle bulk head harness. This throws 3 codes a) P0117Coolant Temp Sensor P0122 TPS c) P0325 knock sensor 2) Disconnect the Coolant Temp Sensor 3) Connect the green diagnostic connecters under the dash driver side 4) Ground out the fan at the ECU What I have replaced 1) Coolant Temp Sensor 2) ECU 3) Every Relay in the engine compartment fuse box 4) Speed sensor 5) I checked every fuse in the car What I am convinced of: 1) I have a Short in the engine wire harness 2) Something is wrong with AC system Notes: I have 8 volts at the wire that connect the engine coolant temp sensor when I disconnect it from the coolant temp sensor
I am not going to sugar coat this for you. There is a 98% chance you blew the head gasket. You will need a compression test, if that does not confirm it, then ask for a hydrocarbin test, that will be the dead give away. Do not replace the radiator before any of this is done. The fix for this job is at or around 1400. Sorry man. I have one now I am try to fix
Look at #2 when the car was delivered it had a check engine light for a speed sensor. I erased it but since then it was only moved a few feet into the garage. 1) Are there any other issues with the way the car is operating? When I purchased the car a week ago the guy told me it had a busted HG. I thought I would fix the fan issue first. 2) Has the "Check Engine" light come on at all during operation? Real funny you mention this, when the car came it had a check engine light with note a speed sensor malfunction. I did not mention this because I never even thought it could be an issue 3) Does the CEL light when you turn the ignition switch ON, before starting the engine? Yes the light does go solid 4) Did the CEL flash (about 3 times per second) when the green test connectors were plugged together? Yes, 3-4 times
Good Lord 1) Regarding my inside fans only working at the highest level. I pulled out the resistor, its all rusted and I see where there is a broken connection inside. How much does it cost. Question, Is there a way this is causing my problem with the fans inside the engine compartment? 2) I unplugged the Coolant temp sensor. And with just the key in the ACC postion and the AC turned on I am getting .002 at the wire. 3) I have a new sensor from NAPA. without plugging the new one into the coolant pipe and just plugging into the harness I am getting the same results. Do I actually need to put it into the pipe. 4) How do I test resistance with it plugged into the coolant pipe. You guys rock.... And a pic of the little nasty bugger included
