2
Everything posted by msmithmmx
Why are you swapping the intake? Here is my stock answer Going to make this simple for you as I have done the 2.5 to 2.2 on a Legacy Outback. I used a 97 2.2. From the donor car (450 dollars tops) 1) Engine / use the exhaust manifold from the 2.2 donor 2) AC Compressor and hoses from your 2.5 mount onto the 2.2 3) Metal Power steering lines from the 2.2 move them over 4) The fly-wheel from the 2.5 will have to be moved over to the 2.2. From Subaru 1) All new exhaust gaskets (10 dollars) 2) new o-rings for the AC hoses you disconnect 3) new o-rings for the power steering lines you disconnect From Walmart 1) 2 cans of 12 oz refrigerant and a refill hose (30 bucks) While you are at it replace this on the 2.2 donor (100 bucks) an easy to do with the engine out. 1) Harmonic balancer (50 ebay) 2) AC and Alternator belts (20 pepboys) 3) Rear cam seal (5 dollars) 4) Oil Separator Plate (sure to be leaking, original is plastic) (15 dollars) 5) Rear main seal. (20 dollars) 6) Spark Plugs (10 dollars) 7) PCV Valve ( 8 dollars) 8) Valve cover gaskets (2 of these) and grommets for the bolts (30 dollars) 9) Reseal the oil-pan and replace both gaskets that are internal. (RTV temp sealer 4 bucks, gaskets are 10 bucks)
My Stock answer to this question Going to make this simple for you as I have done the 2.5 to 2.2 on a Legacy Outback. I used a 97 2.2. From the donor car (450 dollars tops) 1) Engine / use the exhaust manifold from the 2.2 donor 2) AC Compressor and hoses from your 2.5 mount onto the 2.2 3) Metal Power steering lines from the 2.2 move them over 4) The fly-wheel from the 2.5 will have to be moved over to the 2.2. From Subaru 1) All new exhaust gaskets (10 dollars) 2) new o-rings for the AC hoses you disconnect 3) new o-rings for the power steering lines you disconnect From Walmart 1) 2 cans of 12 oz refrigerant and a refill hose (30 bucks) While you are at it replace this on the 2.2 donor (100 bucks) an easy to do with the engine out. 1) Harmonic balancer (50 ebay) 2) AC and Alternator belts (20 pepboys) 3) Rear cam seal (5 dollars) 4) Oil Separator Plate (sure to be leaking, original is plastic) (15 dollars) 5) Rear main seal. (20 dollars) 6) Spark Plugs (10 dollars) 7) PCV Valve ( 8 dollars) 8) Valve cover gaskets (2 of these) and grommets for the bolts (30 dollars) 9) Reseal the oil-pan and replace both gaskets that are internal. (RTV temp sealer 4 bucks, gaskets are 10 bucks)
A 2.2 for 400.00 is to much, I would offer 200.00. Given no facts. you may have to reseal the engine. The 2.2 swap needs a few things other then the motor. Make sure the 2.2 includes the exhaust manifold. 1) Engine / use the exhaust manifold from the 2.2 donor 2) AC Compressor you must keep and hoses from your 2.5 mount onto the 2.2 3) Metal Power steering lines from the 2.5 move them over 4) The fly-wheel from the 2.5 will have to be moved over to the 2.2.
When I replaced the gasket (RTV) the engine was out. With the engine in the cross member is blocking you from getting access. Bottom line, this is a big job with the engine in. CAUTION !!!! You will need a engine pick to support the engine from above as you will need to remove the lower crossmember and exaust.
For the past 6 months the alarm system on my 98 OBW is being set off by other people locking or unlocking their cars. When I am at the mall it goes off at least once and my next door neighbor sets it off every morning. Do I have a failing alarm system module? What to do... Other makes and models not just sub's set it off
I FEEL your pain. When my sub overheated I had it towed to a local shop were they told me my radiator was restricted, they replaced it for 450.00. On the way home from picking it up it over heated. The shop you went to as did I is better left to brake jobs and winshield wiper replacements. I would consider this a lesson learned but if you want to brake stones you could ask for the cost of labor back. In the end I opted not to replace the head gasket on my 2.5 and replaced the engine with a 2.2. Looking back if I had known about this website I could have saved that 450.00.
I am getting ready to do the timing belt on my 2.2. I need to pull off the right side pulley to do the cam seal that is leaking like. Once it’s off and if it spins a little is there a method of getting it back to top dead center. Also what cylinder is Number 1. I suppose I could mark it but is there a better way. Also, I need to remove the crank pully, any pointers on this?
