2
Everything posted by msmithmmx
Here is what I did when I had the engine out 1) Harmonic balancer (50 ebay) 2) AC and Alternator belts (20 pepboys) 3) Rear cam seal (5 dollars) 4) Oil Separator Plate (sure to be leaking, original is plastic) (15 dollars) 5) Rear main seal. (20 dollars) 6) Spark Plugs (10 dollars) 7) PCV Valve ( 8 dollars) 8) Valve cover gaskets (2 of these) and grommets for the bolts (30 dollars) 9) Reseal the oil-pan and replace both gaskets that are internal. (RTV temp sealer 4 bucks, gaskets are 10 bucks) 10) new o-rings for the AC hoses you disconnect 11) new o-rings for the power steering lines you disconnect
And the answer is Ebay. I suggest you use an upgraded Subaru OEM Radio, I know it works as I have done it. I was unable to find your exact radio on Ebay but they always pop up. Just search for "subaru radio" every few days. They should cost around 15 bucks. Upgrade 6 disk with tape http://cgi.ebay.com/ebaymotors/02-03-Subaru-Impreza-AM-FM-6-Disc-Cass-Radio-Changer_W0QQcmdZViewItemQQcategoryZ38641QQihZ009QQ itemZ190065857698QQrdZ1
And the answer is Ebay. I suggest you use an upgraded Subaru OEM Radio, I know it works as I have done it. I was unable to find your exact radio on Ebay but they always pop up. Just search for "subaru radio" every few days. They should cost around 15 bucks. Upgrade 6 disk with tape http://cgi.ebay.com/ebaymotors/02-03-Subaru-Impreza-AM-FM-6-Disc-Cass-Radio-Changer_W0QQcmdZViewItemQQcategoryZ38641QQihZ009QQitemZ190065857698QQrdZ1
First, the overflow tank aside for now are you able to locate an external leak? If so you may have good results with the Subaru stop leak coolant conditioner. If not you have an internal leak, to verify this I would take some of your existing antifreeze to an engine shop and have them test for hydro-carbins. This will just confirm what we allready know. If you change the head on one side you should go ahead and do the other since you will have so much from the top of the engine allready off. You might want to check with the dealer, you may be covered under the HG extended warrenty sinve you are under 100K
Cookie, you left off the fact that you probally don't drive those BMW's daily and leave all the work to the Subaru (as you should). Regardless, I can't belive its has been cheaper to maintain those cars. Question for all, When is the last time you have seen an old BMW on the road? When is the last time you have seen an old Subaru on the road?
I replaced mine due to a blown head gasket. I did not have the skills to replace the Head Gasket but I did have the skills to replace the engine. I used a 120 peice tool set from Costco, impact wrench and a borrowed cherry picker. From what I have learned I could probably do a head gasket on a 2.2 if I had to now.:cool:
Another Sub soap opera "As the engine turns". That engine has over-heated a few times! Are you sure you still want to use it? You might want to start looking for a 2.2 and have that shop swap it. You can grab a JDM of EBAY for a few hundred bucks. You might get lucky and find a wrecked chassis on ebay with engine. I found one there.
I bought a 2.2 engine (ebay) that I could do a dry run on before I actaully do the timing belt for real on my production 2.2. I noticed a leak on the mock engine behind the pully on the rights side. I then checked my working sub and it has the same leak (real wet). What seal is this and is this common.
