2
Everything posted by msmithmmx
Nipper is correct, you will need a hydro carbin test. Any engine shop can do it. Think of it as this, you engine is shot or at least 1500 in repair. The car is worth 2800. You never know what else could be wrong when your engine overheats. Try the coolant conditioner from the dealer. I see you having only one option. Install a 2.2.
Got to be honest with you, this sounds to high. I always have to think twice when I go in for something simple and 1500 dollars later I am told everything is fixed. I recently brought my sub in for a state inspection and they wanted to replace my steering pump because it made a noise. I told them to tighten the belt and the noise was gone.
I'm home...
msmithmmx replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It's that 2.5 causing your problems. Get a 2.2 -
Hold on here, your 97 2.2 does have an egr. I have done what you are doing. This ia a past post of mine Going to make this simple for you as I have done the 2.5 to 2.2 on a Legacy Outback. I used a 97 2.2. From the donor car (450 dollars tops) 1) Engine / use the exhaust manifold from the 2.2 donor 2) AC Compressor you must keep and hoses from your 2.5 mount onto the 2.2 3) Metal Power steering lines from the 2.5 move them over 4) The fly-wheel from the 2.5 will have to be moved over to the 2.2. From Subaru 1) All new exhaust gaskets (10 dollars) 2) new o-rings for the AC hoses you disconnect 3) new o-rings for the power steering lines you disconnect From Walmart 1) 2 cans of 12 oz refrigerant and a refill hose (30 bucks) While you are at it replace this on the 2.2 donor (100 bucks) an easy to do with the engine out. 1) Harmonic balancer (50 ebay) 2) AC and Alternator belts (20 pepboys) 3) Rear cam seal (5 dollars) 4) Oil Separator Plate (sure to be leaking, original is plastic) (15 dollars) 5) Rear main seal. (20 dollars) 6) Spark Plugs (10 dollars) 7) PCV Valve ( 8 dollars) 8) Valve cover gaskets (2 of these) and grommets for the bolts (30 dollars) 9) Reseal the oil-pan and replace both gaskets that are internal. (RTV temp sealer 4 bucks, gaskets are 10 bucks)
