eventoday
Location
denver
eventoday's Achievements
USMB is life! (4/11)
10
Hello, I have a 01 outback, automatic and 230k miles. about 2 months ago i had my front brake pads done and disc turned. Now 2 months later my abs light comes on after driving for about 5 min. When I turn the car off and then turn back on it takes 5 min for abs light to turn back on. Where should I start. I am not sure if it is related but also when my car is off and I hit the brakes the dash lights come on. ???????? thanks you guys are the best Jake
Im sorry I meant volts. The guy at autozone said 12.6 was alright but I thought it was low. Why would there be no battery in the morning though. It seems like the alternator is doing enough to keep the car running? why would the battery discharge? just a thought before I go spend a $160. thanks again Jake
Hi, I have 01 outback. It has 220k miles. Recently while driving my battery, abs, and brake light came on. Within a minute they went off but the ABS light would turn on when I pushed the gas pedal and off when not pushed. Now I have had those 3 lights turn on, on another subaru and 20 minutes later the car died and the alternator had died. So I took the car to autozone and they tested the altenator. They said it was good. I noticed it showed 12.6 amps. I dorve the car for 2 days with the ABS light coming on and off. Then yester morning the car had no power. I didn't leave anything on. I jumped the car when I got back from work. I drove it for about an hour and no problems. When I returend home I turned it off and started it an hour later with no problems. This morning dead. Also the battery is new within 4 months. any ideas? thanks Jake
hello, I have an 01 outback with 214k on it. I have been noticing a metal sounding clank when i hit bigger bumps. Sounds like it is coming from under the the middle of the car. i have looked under the car but haven't noticed any missing bolts or anything that looks unsecure. I know this is kinda vague but any ideas? could it be anything to do with the transmission:slobber:? thanks jake
hello, i just purchased an 01 outback ej25 with 214k miles. i purchased it for $2200 from a dealer who got it on trade in. with the high miles i figured it was a good buy. i am noticing a metal sounding clank coming from underneath me when i hit large bumps. any ideas? where should i start. justlloking under the car everything looks secure thanks jake
Hi I have an 01 forester. I am putting my amps in it and need to bring power into it. Don't see any holes under the dash I can bring a wire in. I do see these holesunder the steering wheel area that have like a plastic cylinder looking plug. not sure if those are actually removeable. any ideas??? jake
Hi, I am putting my amps in my new 01 forester. I need to bring the power wire from the engine into the car. I got up under the steering wheel under the dash to look for any holes i could go through. I didsn't see any. I did see thes hole-plug looking things. Kinda looked like i could pull them out and bring wires through. (possibly that is what they are for????) any ideas?
