Leeroy
    3
Everything posted by Leeroy
  1. Swap the 1983+ complete ventilated disc brakes from 1983+ EA81 engined models. Calipers, rotors, backing plates and hand brake cables will all swap over without issue. They might be getting hard to find these days but it should be easier to source than the earlier stuff.
  2. Just a note that 1972 to 1977 door handle trim cups do not, in my experience, ever completely degrade like the later versions. They were only available in black, not matched to trim colours like those after mid '77, and are incredibly robust. Whatever changes were made to colour the plastic means the sun basically cremates them over time.
  3. Did you use the Hitachi throttle lever and accelerator cable bracket with the Weber or the Weber parts? Original is best. The Weber is very susceptible to a sticky throttle if you overtighten the nut on the throttle lever/throttle shaft. It is really meant to be 'just done up' and the tab on the lock washer bent over. It is really easy to overtighten this nut and the stickiness will be worse when the engine is warm or hot.
  4. If you are on Facebook Drano you should join this group: https://www.facebook.com/groups/1603473039901513/?ref=br_rs
  5. It is my understanding the central/passing light only came on models with single/dual headlights, never on the quad arrangement as you have. So the grille will need to be modified/cut to work.
  6. To get on the bandwagon (late!) OEM intake gaskets ONLY!!!
  7. https://barnfinds.com/not-so-handsome-1959-hansa/ http://www.curbsideclassic.com/automotive-histories/automobile-history-german-deadly-sins-the-bayern-cycle-part-2-a-four-wheeled-titanic-named-borgward/
  8. The only thing a Subaru engine shares is the flat four configuration. Any 'cut-away' pic will show you that!
  9. To mount the rear disc brakes you need to grind some of the backing plate away (on the back) and cut a notch in the trailing arm so you can access one of the caliper bolts. All very easy to do. Ideally you will need to fit a proportioning valve too, either the original EA82 one or something aftermarket. Without one you will always lock the rear brakes in hard stops.
  10. Or as you are in Australia you can just buy a new OEM one on eBay AU
  11. There are HELP branded window winder handles on eBay US all the time. These are the diecast/plastic insert versions (up to the early EA81 1980s Subarus) and they will fit the Brumby/Brat (as noted by dfoyl above). While they do break, as they are cast metal, it will take a long time for that to happen!
  12. While the water choke is probably better than the electric choke in the grand scheme of things, the Weber electric choke is far more reliable and easy to set up that the original Subaru/Hitachi version. Makes for a simple conversion too, as there is far less to set up.
  13. Of course it is possible! The front radiator panel is different but it seems you are already on to that!
  14. I concur, good luck! I have a 1976 GF and there a still a few others left getting around in Australia, at least. Mine has been modified by the previous owner (EA63 heads and cam, different carb) and while no doubt an improvement it is not earth shattering!
  15. They already have ruined millions of threads accross the internet... Surely only a matter of time before Photobucket is gone too.
  16. Yes... They are the same thing. The only difference is between manual and automatic. The automatic has an additional built-in reservoir for the trans fluid.
  17. Be careful with the polyurethane versions as I have seen on many VW sites that they simply do not last and chew up very quickly.
  18. You must use the proper OEM or correctly remade wheel nuts on these rims, no ifs, no buts! Yes they are a conical or spherical shape seat. Anything else will result in damaged rims or far worse.
