7point62fmj
About 7point62fmj
  • Birthday 06/16/1977
  • Location
    Mondamin
  • Interests
    Weight lifing and shooting things
  • Occupation
    extra for adult films
  • Vehicles
    04 wrx cobbII, 87 brat
7point62fmj's Achievements
Eat, Live, Breath Subaru
Eat, Live, Breath Subaru (5/11)
11
  1. looks like a evo a bit and are those finder flares 2D or 3D they should just save money and spray them on... It looks alot like every one else.. Oh wow good for them.:-\
  2. When you did a search on this using the search feature what did you find? There are more then a few threads on it.:cool:
  3. I think I will head off to napa and see what they can do. IF not then I will make some from bolts. Any guess on a good lenght. I have a heli-coil job to do first on the hole. http://www.ultimatesubaru.org/forum/showthread.php?t=118774&highlight=heli+coil
  4. check your audio setting on the clarion. It is easier to destroy speakers with too little power then to much since the square wave kills faster. Mostly.. mostly having more power helps with THD and gives you more head room.. ie playing louder but clearer. I would pull the speakers out and try hooking them up to another audio sources and see if they still sound bad. Also try different speakers using the same radio. You may have a bad head unit with a blown mosfet or something. Don’t forget to check your impedance also. Are the 45 watt speakers factory? If all else fails verify your grounds. Ground loops are a common problem and can amplify with more volume. Some cars did use the chaise as a common ground for their speakers.. A big pain in the ars.
  5. slow down Ron it is 3ish in the morning. Most of the subaru ninjas are still sleeping from staying up late working on ej swaps from the night before. Patience young grasshopper
  6. I need one and I have a parts brat. Now the question is it easier to order one and where could I get one at..or is there a possibility to get one out of my parts brat. Has anyone ever tried to pull one out is it worth trying? Dont want to dig it out of the snow to find out it is useless.
  7. Is this a coarse or fine thread. I need to know because they sell both kits in the 10x1.25
  8. I am going to try to set up a pump in a tray and run it for a few hours onced hooked up.
  9. Mic brat is also running one of the MSD6's on his car. Not sure which one.
  10. I am going to try this the I will run with mics thing (post #8) more cold weather friendly. Now I got to get some descaler I like. http://www.ultimatesubaru.org/forum/showthread.php?t=66721&highlight=Heater+Core
  11. http://www.ultimatesubaru.org/forum/showthread.php?t=66721&highlight=Heater+Core
    I think I will just do what the last poster here did. Now I just need to find a descaler I like.
  12. yep the wrest are studs this one is just a bolt due to the last owner.:-\
  13. http://www.ultimatesubaru.org/forum/showthread.php?t=73517&highlight=Heater+Core I think I am going to try this first and yes I know there are issue with making the heater core leak.
