boostkits
About boostkits
- Birthday 04/15/1970
Contact Methods
Website URL
http://boostkits.com
Location
South River
Interests
My Car
Occupation
My Car
Vehicles
SUBI 03 WAGON
boostkits's Achievements
Newbie (1/11)
10
Just what's listed.
Those of you guys into cosmetic upgrades need to check out this new dash kit. It's made from genuine Carbon Fiber Material, not that painted plastic. It's coated to prevent yellowing and the fit is spot on. Much nicer than other kits found on the web. 02 WRX Manual 02 WRX Auto 02 1/2 03 WRX Manual 02 1/2 03 WRX Auto 04 WRX Manual 04 WRX Auto 04 Sti 05-06 WRX Manual 05-06 WRX Auto 05-06 Sti 05 Forester Manual 05 Forester Auto 05 Forester Manual w/climate 05 Forester Auto w/climate 05+ Legacy (coming soon/ pre-order) http://boostkits.com/worx_tuning_interior_trim.html E mail me if interested.
I have more options but no sales at this time. MOMENTUM is a new up and coming turbo company, APS is a good turbo but mucho $$$, PERRIN just came out with a turbo kits. $2600 + sh GT30R Kit: GT30R turbo, reflanged uppipe & downpipe, oil & water lines, and Tial 44mm wastegate and intake. Full boost is around 3800RPM on the .63A/R; 4200RPM for the .82A/R. The .63 A/R is smoother. $2800 + sh GT35R Kit: .82AR GT35R turbo, reflanged uppipe & downpipe, oil & water lines, and Tial 44mm wastegate and intake. Full boost is around 4700 RPM. $359 + sh 4" Rotated-Mount Intake System: Attaches to a 4" turbo inlet and tapers down to 3" to meet a 3" 'BIG MAF' oversize MAF sensor housing. Offers all the provisions for blow-off valve recirculation and the crankcase vents and includes PSP-ENG-852; a pipe to adapt the Perrin FMIC piping to a Garret turbo.
Here you go... IHI vf34$849 IHI VF 34 Series Ball Bearing Turbo This is the perfect Street turbo, response, and power wrapped into one! Its our most popular seller. For putting 300 + hp to the wheels, you need a bigger turbo. This is a ball bearing design which gives quicker spool up. We recommend STI injectors/ Fuel Pump when upgrading to this turbo + an upgraded ECU. Check out our price with a US 12 month/12,000 mile warranty! IHI VF30 $800 IHI VF30 - Split Thrust Bearing Design For those that want the STI upgrade - but don't care for the whine of a ball bearing turbo, the VF30 is your choice. Same power as the popular VF34. This is the best valued street turbo on the market! IHI VF22 $799 IHI VF22 - VF22 is the big gun from IHI. Push 20+ PSI through this baby. Again, highly recommended upgrades: Walbro pump, STI pink Injectors and engine management software. Contact me if you have questions about this upgrade.
Hmmm - Not sure what I meant when I wrote that. I think I meant to write the vf34 had faster spool than the vf30 which uses a journal bearing. (not roller). I'll have to change that. The VF34 is a ball bearing turbo. However it has a 1 yr waranty from IHI. If you have a problem you just contact me and I arrange to get it checked out by IHI. It isn't rebuildable and you can't get replacement cartridges from IHI for either turbo. VF30 are split thrust journal bearings. Journal bearings are more robust and quiet compared to the BB. Roller bearings were used on the older VF series turbos (VF24/22/23 etc)
I'm trying to move a large amount of turbos. There are 3 to choose from: These turbos are from IHI and all have a 1 year warranty!!! IHI vf34$849 IHI VF 34 Series Ball Bearing Turbo This is the perfect Street turbo, response, and power wrapped into one! Its our most popular seller. For putting 300 + hp to the wheels, you need a bigger turbo. This is a ball bearing design which gives quicker spool up. We recommend STI injectors/ Fuel Pump when upgrading to this turbo + an upgraded ECU. Check out our price with a US 12 month/12,000 mile warranty! IHI VF30 $800 IHI VF30 - Split Thrust Bearing Design For those that want the STI upgrade - but don't care for the whine of a ball bearing turbo, the VF30 is your choice. Same power as the popular VF34. This is the best valued street turbo on the market! IHI VF22 $799 IHI VF22 - VF22 is the big gun from IHI. Push 20+ PSI through this baby. Again, highly recommended upgrades: Walbro pump, STI pink Injectors and engine management software. Contact me if you have questions about this upgrade. Make it a power package: Add STI PINK INJECTORS & WARLBORO FUEL PUMP. PM me for a price.
I have more products from WORX Tuning . More about it: The WorxTuning SK-ERGO is available for your Subaru 5 & 6 speed application. The CNC machined bodies are made of a durable black synthetic material which looks just like black anodized aluminum, but will not get hot and burn your hand in the summer time as a metal bodied knob can sometimes do. The top plate is CNC machined aluminum which features the WORX logo and is finished to perfectly match your interior. http://boostkits.com/worx_tuning_sk_ergo.html The Dead Pedal: What our cars should have come with from the factory, only better. The WorxTuning OEM Match Dead Pedal is a work of art you will love to step on. It is meticulously CNC machined front and back from a solid block of 6061 aluminum, satin finished, and clear hard anodized for long term durability. The countersunk rubber pads mimic the pattern on the factory pedals and the pedals retain the factory mounting clip design. Additionally, our pads will not fall off like cheap stick or glue on pads used on many aftermarket pedals. Plus they are replaceable if worn. Battery Tie Down: The WorxTuning battery tie down is a clean and stylish addition to your engine compartment. CNC Machined from 6061 Aluminum and finished in Signature Smoke Anodize, we set out to make a high quality machined tie down that would be a tasteful addition to any Subaru (not a big WorxTuning advertisement). PM me if interested.
I'm not on NASIOC just WRXFANATICS & CLUBWRX. I will be on I club this year. And legacy GT also.
I have both Turbo XS turbobacks in stock. RFL T1 ($1059) Standard Turbo Back ($1035) I have 6 Nur Spec catbacks ($559) 1 Nur rear section ($359) I have 1 Borla 14978 2.5" ($479) 12 x Borla 140053 Hush ($539) 6 x 140075 XR-1 Borla ($559) 5 x HKS Hi-Power ($499) 2 x Perrin single ($649) 1 x Perrin twin ($649)
NEW PRODUCT! WORX Tuning new version Cat Back
boostkits replied to boostkits's topic in Products for your Subaru
I carry TURBO XS, BORLA, BOSAL, PERRIN the most popular. I'll try to post up a list of prices today & I'll pm you the WORX TUNING. Anthony -
If you're looking for a Cat back this is one you should check out WORX TUNING CATBACK. WORX tuning has been developing this forever and they got it right. Heres a pic: reply w/ your zip and I'll shoot you a price. Features: Full 3" - NO RESTRICTION Minimal Bends - SMOOTHEST POSSIBLE EXHAUST FLOW Beefy Hangars - YOU WILL NEVER BREAK ONE OF OUR HANGERS (pictured below) Flex Joint - NECESSARY FLEXIBILITY FOR LIFETIME DURABILITY (pictured below) High Tolerance slip fit joint - for installation ease, flexibility, and weight savings(pictured below) Fully polished aircraft grade 304 Stainless Steel Construction Includes all necessary clamps (heavy duty T-Bolt design), hardware, and gaskets Made in the USA with a LIFETIME WARRANTY
Wow - that's cool! I'm liking this forum. I'll be sure to post up any new products that come my way. If you're like me you're already sick of all the generic stuff that's getting peddled around on the forums. I try to find different things that other vendors can't get or don't even know about. My Subi is a pretty stock 03 wagon. I'm so busy trying to run things over here my own car is the last one that gets anything. Usually the parts I put aside for myself I let go to a customer that really wants it. So if you guys are in the market let me know what you want. i'll try to hook you up with nice price. I can usually beat any price on the web. I run my shop myself so I can keep prices down.
I stumbled across this forum in my search to find a new FORUM to sell parts on. Please let me know how I can become an authorized USMB vendor. I carry WORX Tuning, Turbo XS, Perrin, APS, Speed Monkee, IHI Turbos, Momentum Turbos to name a few. Thanks, Anthony@BOOSTKITS.COM
