Location
Oroville eastern wa.
Interests
hunting, shooting
Occupation
contractor
Biography
so far in the woods you can;t get here from there.
Vehicles
85 sube4x4 , 84 sube 4x4
kamakazisubee's Achievements
Advanced Member (3/11)
10
Im thinking about putting a snorkel on my sube,but I have a few quetions about what kind of material to use and what size do I need. THANKS, JORDAN
Hey I work off a diesel gen, plus i have a kerosene refer, solar panels and batteries. I'am set JT:headbang:
I believe there is a very good possibility of a strike on the US, in the near future, most likley the coasts. I'am inland but emp could still reach here.
Just wondering if anyone knows how to emp proof an ea82 sube? I understand the principal and am in the process of emp proofing solar, generators, ect. seems to me a car body is a faraday box just needs to be grounded good ??? any comments would be helpful. Thanks JOE:headbang:
$25 for a thermostat!
kamakazisubee replied to Subieguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can you say stand and deliver ?? -
Where can I find ,rectangular air cleaner 4 1/2x6 3/4 x2 5/8 with K&N filter for weber dfav carb Thanks for any help JOE:headbang:
Clutch Replacment Questions
kamakazisubee replied to mudduck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My 15 yr old pulled the engine on my sube and replaced the clutch, he and his brother and i lifted it out by hand in our open air garage. one day total; very easy,just mark all wires and hoses . good luck JT. -
What is the process to leave feed back on itrader ? I have bought from several people on this board and would like to leave feed back for them thanks JOE
Gas pedal stuck to the floor
kamakazisubee replied to Gyoas759's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just had to fix mine although it would pull back up by hand. The pedal gear attaches to a pin with a barrel shim I had to take it off about 3/4 of the way and use pb blaster on it . work it around a bit and put it back together. hope this helps JOE. -
another webber carb question ( auto choak)
kamakazisubee replied to kiwi subbie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My son just installed a dfav weber on his 87 wagon the dfav has the choke on the back side all else is the same he has power steering and a choke on the front would not fit, plug in to the hitachi choke wire and you are good to go. -
Thank you GD my weber must have been off a 6 cyl. it had 175/200 now I have a starting point Thanks again JOE> :banana:
I know that I saw the jetting for a weber on a ea 82 engine, but can not find it now. is it somewhere I haven't looked?? or does someone have that info. many thanks JOE.
EA82 Transmission Stuck
kamakazisubee replied to Pooparu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Doe's the trans shift into different gears ? if so try backing up while shifting out of 4wd good luck JOE:Flame: -
I want to thank the board and members that answered my oilpan question what a great site and members THANKS AGAIN JOE. :clap:
