Crawlerdan
6
Everything posted by Crawlerdan
no way!!! your from somers? last summer i moved an electrical transformer in over near the best western. i absolutly fell in love with teh flathead valley, i miss it weve been thinking of moving out there what is the weather like right now? got any lines on a job
i think, for many many reasons, you are barking up the wrong tree awd/4wd pltforms do not have the handleing characteristics that a desirable drift car has, as in NO caster
our cars, as well as most, use an idle up sequence to warm themselves the cars starts when cold, idles at 1500 or so, then drops down to a standard idle how long does this take in your car? how long is it supposed to in a 91 ej22 5spd? the reason i ask is i installed a new IAC and i want to insure the car is healthy now
well, the car is lifted a little, i have forester struts and front springs, as well as forester trailing arms everything works perfectly, and im quite happy with how it sits, i dont really want to go any higher the issue was-slight rubbing under severe bumps- most of the time not a big deal- what i wanted to prevent was the whole family and gear in the car-it would have happened alot more, and pissed me off. the rubbing was only in the last 25% of suspension travel., but when loaded would have been far more noticable problem solved now, i could put a larger tire on now with no issues
most flywheels/flexplates are designed to go on only one way- for balancing the uneven spacing insures proper installation
ive got a 91 wagon with forester gr2s, and big tires, no lift otherwise. when loaded with weight or i hit a big bump, tires kiss body not a big deal, and it doesnt happen enough to care about, but i am planning a 3k mile drive with the whole family and gear- so it will happen frequently on my trucks ive added a simple air shock, add air= increased carrying capacity i want to do the same to teh legacy- like weld on mounts to the lower a arm, and make a bracket at teh body to hold teh other end. anyone done something similar?
GIGGITY:banana:
i too would like a price and date of availiability, ill probably pick one up
well thanks for the reply- i definately do not have a vac leak, i have a guage and monitor it like a hawk (part of my hypermiliage techniques) i havnt seafoamed it...might try that is there an IAC adjustment? also i think the air fuel mix is off, its the screw on top of the throttle body. what are teh proper setting procedures?
ok first- i just spent an hour searching and reading -so lay off i have a 91 legacy wagon, ej22, 5spd ive had it for a few months and noticed it idles high, dont really car, but im sure i would see better mpgs if it was correct. it idles at 700 or so after warm up sequence- good after a few miles it will creep up to 1050 or 1100 thats a little high for me no CEL, runs perfect, seeing no other problems, and getting 38mph hwy (im an ametuer, and SAFE hypermiler) sugestions?
you would be alot happier with a 2.2 that ej22 is considered the best motor made by many in the subaru world the 2.5 will offer you a little more horsepower, but will cost you greatly in the reliability department, and they require a tad more room as they are quad cam...unless you go with the SOHC 2.5 which is badass, but all phase 2 and obd2...wiring headache compared to what you just did. buy another donor car and have at it buddy...i might have another soon
