Crawlerdan
    6
Everything posted by Crawlerdan
  1. not only does she have 405k on her now, but shes feisty enough for a 4200 mile round trip around the west coast and on to the famed rubicon trail! no i didnt do the whole thing, but i did play on the slabs and raise the eyebrows of many jeepers
  2. great find man!! the whole auto retract thing failed, complete failure, stuck half open
  3. first gen leg with auto belts, they failed...duh they all do customer wants to know if i can install seatbelts out of a newer legacy in her car, anyone done this? im sure its easy but want some feedback before i spend her money
  4. 1991 lego, original head gaskets, just basic maintenance , also lifted 4 inches
  5. if you want a turbo engine- you will need to modify your xmember for an up pipe, or use a turbo member legacy turbos used the ej22t- it will bolt in fine, your ecu will probably run the turbo, but not safely, you will need a stand alone harness, or swap to a turbo set up you can use your trans and rear diff. but they will live on borrowed time if you boost them hard. shrapnel for the trophy case definitely
  6. ive relocated the switch many times, dash, console, steering wheel on a rally car lol if the switch itself is ok, just relocate it
  7. well crap its an aux filter. which means you should have had a tow pkg from factory. weird look here-http://parts.subaru.com/a/Subaru_2005_Outback25L-4AT25I/_52093_6022085/AT--TRANSMISSION-CASE-ATF-FILTER/B13-154-09.html
  8. no filter, probably cooler lines. the filter is on the drivers side trans case on those years
  9. yes a vw trans cam hold that power, they do thousands of times a day, if they are in decent shape the ej22 into a vw is a common swap
  10. i recently had the same symptoms. i discovered that the stock high mileage fuel pump was fine on the stock engine, but the cams allowed more air and fuel (duh) and the pump couldnt keep up at higher rpms. replaced it with a new one and tahdah not sure if that will help, but thats what happened here
  11. i have many times, i have an 89 loyale right now with 2 inch spacers in front only, just add to the strut tops, no need to mess with cross members or steering good luck
  12. mmmm tasty old iron there buddy
  13. well said jeszek. couldnt have said it better. good techs that are honest are few and far between. youll find home soon. if i could afford you youd have a job here brother
  14. ya....youll fit right in.we need more info and more pictures . subaru porn appeases the masses haha
  15. im having problems ordering goodies using the ambassador bucks? any ideas?
  16. no. you will need a 2.2 intake, and find a way to run an egr valve
  17. hello from the bitterroot valley. i was in libby thursday welcome aboard!
