NV Zeno
    10
Everything posted by NV Zeno
  1. There are a series of flaps (or doors) behind the radio box, that are connected to and controlled by your temperature dial and flow direction dial, with rods and cables. If you're lucky, one of those has just fallen off at either the dial end, or whatever it's controlling. The weakest points are commonly a little plastic "tang" (for lack of a better term) that one end of the cable connects to, that weakens over time and breaks off. Best access is from the driver side..there's a link to a heater core replacement "how to" that'll at least show you where to start looking, and what to take apart to look in there. As soon as I find it, I'll post a link. *Edit/Improvement*: Here's the link, many thanks to Mick: http://www.ultimatesubaru.org/80s/mick/mick-usrm/heatercore/heatercore.html Good luck, .
  2. "Mudisfun - I'll send ya a vid a little later when we have a little more footage to work with, I just don't want you to be left out if I send one and then add more to it." Well then..looks like you're gonna have to make some more footage:grin: . Whaddya say NV crew, are we up for a little "modeling" soon?
  3. Big Blue, you recognized Jumbo from those tiny snippets? Sounds like you're a regular there..maybe you'd care to join us soon:grin: .
  4. I'm figuring on leaving The Ranch bright & early Thursday, probably crashing in Eugene (as we did for WCSS3),and arriving at the show in late morning. Brian, if you want to do that again (goes for you too, JB and Jeremy), we can hit a hotel (a different one this time:rolleyes: )...I'm getting too old for those 13 hour "bombing runs" anymore:lol: .
  5. Both types are acceptable, but I'm leaning toward the mug...12-16 ounce size would be optimal. Prefer etched (for "voting" purposes). No opinion or preference on logo design. Definitely in for a personalized unit.
  6. "Have you taken your hub apart to make sure theres nothing caught up in there? Maybe some mud from WCSS" Nah, I don't think it's WCSS mud, heh heh. The sound is almost like a CV axle gone really bad, but replacing them (both) didn't change anything. I've talked to a few other Subaru guys (and repair shops), most agreed that the hub is probably at fault..I'll replace it and see what happens, then report back here. Hey Brian, got a few minutes for some wrenchin'? :lol:
  7. Brian, I don't think the knuckle is the part at fault, but the hub that's (I think) bolted to the brake rotor on the outboard side. It doesn't appear from the diagram in the FSM that the ball joint needs to be separated at all, as if I was removing the axle.
  8. '83 4X4 wagon, nearing 300,000 miles: After replacing front axle countless times with no change in remaining noises and performance, I've decided that the hub is the culprit, and have decided to replace it ('83 FSM, page 9-25 "Wheels and axles, Component Parts" fig. 9.65, #11.). Any special tools or parts needed, or is it just axle nut, washers, 4 bolts to the rotor? Is a used hub usually good, or is new the way to go? Am I asking the right questions:lol: ?
  9. Totally a suggestion here (and certainly not to diminish last year's mug, it's great), could we perhaps have a smaller, more standard sized mug? 12~14 ounces seems big enough, the 20 and 24-ouncers seemed a bit big and cumbersome. Just my 2 bucks
  10. Yes, CV of Ocala..Kevin and his crew are the best. I wouldn't consider another source. A VERY satisfied customer!
  11. Maybe we should start a separate thread for the glasses/mugs? Just my 2 bucks
  12. Wow..lots-o-elbow room. Looks like Stagecoach, or maybe Silver Springs. I guess you're getting a little taste of the breeze that's blowing there about now:rolleyes: .
  13. If chrome, DON'T use steel wool/Brillo. One of the cheap-o liquid car waxes worked for me, or (if you can find it) "Chrome Polish" = liquid in a bottle/can...works even better. After cleaning them up, give them a good coat of wax. It helps repel the snow and mud (and water) a little. I spray the backs with a light coat of WD-40, it helps slow the rust and corrosion some. Just my 2 bucks
  14. Actually, I enjoy the long trips to the WCSSes. It's nice to get away to a beautiful setting for awhile, the event is a destination. Of course, meeting and hanging with other Subaru nuts is extra bonus:D .
  15. Yeah, I like the color version with the star at Shelton. I agree that the smaller lettering could be less uh.."fancy", easier to read. I also agree that a few hundred miles is a short distance to drive to attend a great "shindig" as this. Gotta get out and see the world! My 2 bucks
  16. Looks like a real blast. I love the snow...
  17. Well, I came home a minute ago, and I heard the fan running. After my "malfunction" last weekend, I had an opportunity to unplug the sensor/switch and clean the terminals. There was lots-o-crud. Didn't think it helped, because I never heard the fan running since then. Guess I never got the engine hot enough to trigger the switch until today. Looks like the simple fix worked. Thanks for all the replies/input. :D
  18. I've got an FSM, the wiring looked straightforward. I'm not looking forward to changing the thermo switch, not really in the mood to be dealing with all the coolant mess. On the other hand, this might be the perfect opportunity to flush the system/change the coolant. Thanks.
  19. Skip, you're right, thanks. I erred in not mentioning vehicle type. It's an '83 EA81, California spec. I'll perform the tests recommended above as time permits this weekend, and report here. Thanks guys.
