Soup
Contact Methods
Website URL
http://
Location
Ottawa, Canada
Soup's Achievements
Advanced Member (3/11)
10
96 Heated Seat ?
Soup replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Sounds like both seats are broken. They are on the same circuit, so it wouldn't be a fuse blown. The best way to find out is to unplug, and meter the connections. -
96 Heated Seat ?
There is heat in the butt, and the back -
96 Heated Seat ?
There should be 4 wires to your seat heater, unplug at the seat, look at the plug that is attached to the seat, hold the lock tab up, there should be 4 pins, the top row is numbered from right to left, 1, 2. Bottom row is numbered right to left, 3, 4. Check for continuity between 1 & 3, 1 & 4, and 3 & 4. if one of those has no continuity, you have a open heater loop. You can replace the loops, somewhat difficult though. -
One thing to note, the noise from the timing belt tensioner should be mostly apparent at idle, it's a intermittent knocking sound. Piston slap should be a consistent knocking sound, which increases in proportion to throttle increases. My 2000 outback has no piston slap, however it did have a leaking tensioner, which the dealer replaced under warranty. The car has 90,000 km.
you adjust the headlight as follows: for the vertical, adjust the inbd screw (found on the back of the assy, you can see the two adjustment screws on the picture in your manual). adjust the vertical until the bubble is centered in the indicator. the horizontal screw is the outbd one, there is an indicator on the screw, the manual says don't adjust it more than 2 segments either way from the center of the guage. Dan
