Everything posted by backwoodsboy
Hey everyone, 1989 ea82 4x4 flywheel. Approx 1 month ago was assembled (the 6 pressure plate bolts) with high temp (600 degree) loctite. **problem** ...now I have to take it apart, as the clutch DISK inside is the wrong one (DONT ask) I dont wanna heat it with my MAPP torch, for fear of messing with the spring steel of the pressure plate...... BUT.... the 6 bolts in question are only torque-spec'd to 12 ft/lbs, so I know they are soft.... and I dont wanna snap them off flush = FUBAR Without heat, what will release first, the loctite.... or will the bolts snap? Does anyone have any experience with breaking this stuff loose? Thanks very much!
Carlisle show May 16-18 2008
backwoodsboy replied to subeman90's topic in Meet n' Greet. Your USMB Welcome Center
Jess and I will be bringing a portable gas stove like last year, with some pots and pans, plasticware and paper plates. (the camping kit) I *do* have coffee filters in there, but they are the flat bottom ones. If the coffee maker takes the "cone" type, I dont have those. -
Lookie What Showed up At my Door!!
backwoodsboy replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No doubt! Looks great Connie. Cant wait to be there, and see in person -
Hey everybody, Im sure this has been covered SOMEWHERE before, but can anyone enlighten me as to what tells the factory fuel pump on a 1984 Brat to pump fuel *all* the time? I turn the key *on* and the pump cycles for a second (primes) ... then shuts off. (This is for the EJ swapped Brat BTW) Im just using the factory pump to fill the surge tank under the hood, but its not going into RUN mode for some reason. (the ECU controlled fuel pump works fine... should I just run a parallell relay off that control wire?) Thanks very much!
That sounds really good! -
look what followed me home....
backwoodsboy replied to jonas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very nice. I was wondering if it was gonna stay in the USMB family. That brat is one of the nicest that I know of... and is the same color as mine. { :EDIT: well, the same color as the BACK half of mine } congrats! -
Employment is WAY over-rated. ...at least FULL time employment. :-\ -
Repair advice (yes, RUST)
backwoodsboy replied to cobcob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also beware if youve not much practice at welding sheet metal. Steel that thin can pull out of line... badly. I always build a little overlap into what Im doing. -
Lessons Learned: What to Take on High Country Trips
backwoodsboy replied to Robert M's topic in Off Road
Nobody mentioned a good medical kit/snakebite kit and first aid manual yet. ESPECIALLY if youre out there for a long time, it may save someone's life. Funny how fast the "focus" changes when somebodys hurt. -
My Coupes Journey!! Is Over..He is in CT!!
You can always trailer it to Carlisle. -
Finish Stripping Gathering May 3rd or 4th
backwoodsboy replied to Bucky92's topic in Meet n' Greet. Your USMB Welcome Center
Ah, yes. Where IS my head? Incidentally, HTKYSA has 2 options listed for pulling a motor. One is "using a hoist" ... the other is "using a neighbor" Wasnt sure about doing this with the weight of an ER27 though I could bring a LONG 4X and we could get 2 people on each side. -
That has been our anthem this spring. (Jess and I) -
Nice. :cool: -
I could probably *make* a hoist out of some angle iron and a bottle jack... but it would take a good portion of the morning. :-\ Better to just rent a hoist. :cool: Now about all this Finnish stripping.... ??? -
I believe that Jess and I are "in" Will you have LB on the road by then U think? ...and you WERE renting an engine hoist right? (or should I bring the tractor?) -
ROFL ... you just wanted to use those!
They are indeed. 175 mm width
Just Some Teaser Pics of My Coupe
This is why I come here. -
That would help. .... dont pick on me TOO much, or I might just bring the TRACTOR. -
Most likely.
I would be and this would be Connie beating me >
