jcsvx
About jcsvx
- Birthday 09/30/1955
Contact Methods
Website URL
http://
Location
indiana
jcsvx's Achievements
Member (2/11)
10
Re: 98 Legacy misfiring on all four cylinders; drives fine Tim this also explains why replacing headgaskets has fixed some of the cars because they have to take timing belts of and why a valve adjustment can fix if they use crank pulley bolt to rotate engine. it will tighten the pulley. OH THE NON BELIEVERS
Re: 98 Legacy misfiring on all four cylinders; drives fine I thought JCSVX was full of it but I just took off my harmonic bal and the key was half sheared Replaced it and drove 45 miles with no problem longest drive without light in a month!!! Re: 98 Legacy misfiring on all four cylinders; drives fine thanks Joe our local dealer had replaced (bad loose) timing belts in the past and thought that was what was fixing the problem but one of the Mechanics remembers having to change the key on at least one of the jobs. this may not fix all of them but it has fixed several
OK we have fixed this problem on three different 2.5s in the last year all three have had loose front balancers the bolts were tight but bottomed out in crank the key-way and key were worn and had to replace key on all three and new washer and shorten bolt one thread (grinder) the loose balancer causes noise and the knock sensor retards the timing until it missfires and turns on cel. Hope this fix works for you too Joe
this seems related to a problem we have seen a loose balancer knocks slightly causing knock sensor to retard timing until engine dies below is our fix OK we have fixed this problem on three different 2.5s in the last year all three have had loose front balancers the bolts were tight but bottomed out in crank the key-way and key were worn and had to replace key on all three and new washer and shorten bolt one thread (grinder) the loose balancer causes noise and the knock sensor retards the timing until it missfires and turns on cel. Hope this fix works for you too Joe
Thanks for all your help joe
CAR IS USED FOR SNOWMOBILE AND NEED EXTRA HEIGHT OR FT. AIR DAM BECOMES A SNOW PLOW. P.S. ITS BETTER TO YELL THAN NOT CAP. PROPERLY.
I JUST FINISHED THE 5 LUG CONVERSION FOR MY RX I USED A XT6 DONOR CAR AND THE CONVERSION IS GREAT EXCEPT THAT THE FT END IS NOW 1.5 INCHES LOWER. I HAVE E-MAILED THE BACKYARD BOYS TWICE WITH NO REPLY ABOUT THEIR FT. END LIFT BLOCKS DOES ANYONE ELSE MAKE THEM? ANY HELP WOULD BE APPRECIATED. THANKS JOE
