86 BRAT
Everything posted by 86 BRAT
Hi all, I would like to buy a Baja (found out yesterday 2006 last year for Baja) The one I would like to get is 2005 manual turbo. does any one have one,like it hate it,the good vs the bad etc. All I can find out about is photos and not much more. also they do not have many for sale in Fla. Any help would be great. Many Thanks in Advance Don
I was told that the eye was for off roading on the 4x4 models and passing on the front wheel models.As for off road it fills in those dark areas just in front of the car so you can see what your about to hit:banana:
I added power windows and mirrors to my brat and I used wiring,center console(disabled two switches) and door panels from same year 3 door. DO NOT forget window relays under the seats
a
Hi Don, I agree with the other guys on venting and muffler mods,I do not think an oil cooler will work unless you canput some air around it. You might be able to add a motorcycle radiator as a pre-cooler to the front of the trike in addition to what you have. Also a clear photo of the rear of trike with the body on might help us help you Don
why me? i love my subie! damn florida lol
86 BRAT replied to dragonfire's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In my neck of Florida a lot of the junk yards cut'em and ship'em over seas or South america for more cash:banana: Go figure:lol: -
What is that supposed to go to?
86 BRAT replied to nkx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
On my BRAT the green plug and the blue plug in that area are to reset the EGR valve timer. If green and green are connected and the dash light is on switch to the blue one(about every 50,000 miles) It's just a reminder light to check the EGR. -
With all the posts I've read I a little confused on what car I should strip the old brake parts. If I am right to convert my 86 BRAT to rear disc I should look for a 85-87 XT turbo 4wd right guys? Thanks for the help in advance Don
flat stock might flex to much,try square tube instead. if you don't want the light coming thru the fun tops put a flat sheet about 4" or 6" inches long under the light facing fwd (a shade if you will).
which rust killer better?
86 BRAT replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pb blaster for me on nuts and bolts, but if you want to stop rust on sheet metal use osfo. (short for osfuric acid) -
Wiring diagram for the power door locks, anyone?
86 BRAT replied to stickedy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Haynes manual in the back of the book -
4WD doesnt work.
86 BRAT replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the vacuum lines are dry or cracked, replace them they cause all kinds of headaches. -
The center light is for off road use to fill in that dark space between the head lampswhen the high beams are on. The wiring diagram is good but radio shack no longer sells the ten amp switch.just a differant 3 amp dpdt.
Just about all the subarus are the same from the back of the front seats forward(not justy) same model year. If your search goes like mine, you will find many. Grab the first one that's in good shape. Change the color later.
