Suzrub
Location
Santa Barbara
Vehicles
I Love My Subaru
Suzrub's Achievements
Member (2/11)
10
I have a 2000 OBW w/ a 5 speed manual. 3 weeks ago we had our clutch replaced, then a couple days ago our gear shift lever pulled out of the tranny. I can put the gear lever back into place but it won't stay in place. For example when you out it into 1st it will pop the rubber boot out of the top of the tranny, there must be some kind of retaining clip that is missing, broken or was not put back in after the clutch job/ Any ideas? Has anyone else seen this?
Thank you! I will check!!!
I have an 1989 4x4 dl wagon (EA82) How do I check if the timing belts are broken? Thanks Casey
Hey all just hoping for a bit o friendly advice. Started my 89 suby dl 4x4 wagon and a bang sound came from under the hood and a puff of smoke followed!! The car starts but there are very loud rapping noises coming fromn the engine, it kind of sounds like a lawnmower, but it will rev up. I know I needed a valve job, for instance when I would get the car on a slant blue smoke would start billowing out of the exhaust pipe ( I think that was the valves). The engine is very loud and rough sounding now, and there is definately a metal tpo metal sound. If I pull the spare tire out and pop off the little timing belt cover could I tell if the belt is shot? Thanks for any advice!!!
Where 2 find Dual Range tranny in CAli?
Suzrub replied to Suzrub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks Big HElp!! Yes I am running on a small budget, a tiny spec of know how and willingness to jump into a project I have no idea how to do but it will be fun!! -
The yard in your area has a good ammount of SooB parts?!! If you have their # I would like to call them and if they have a Dual Range. I would drivre up there to get it!! I live in Santa BArbara. -
Thanks, I'm switching from a single range to dual range. Will I need to get the same year dual range? (89) Are Turbo trannies and non-turbo trannies the same gearing ratios? -
Anybody know a good pick n pull or have any knowledge of where to find a dual range transmission in california? I am actually in Central CA. I just talked to aguy in texas that says he imports these trannies from japan w/ 30,000 mi for $295? A little steep for me!
Is it possible to change my 89 single range DL to a dual range? It would have to be an EA82 dual range right? I have a 5 speed now? Thanks!!
The GL D/R bolts right IN!!!!!! What is D/R ? is that the transfer case that gives you hi and lo range? Thats awesome if that's the case!!! I would definately keep this car if I could do that!!
Just wondering what I should check out? How much is a turbo to fix? Can you get replacements? I should make sure there isn't the typical knock in the engine? I really want a Dual range wagon so I can get it set up to take me where I want to go!!
I am more looking for a little clearance up front. But I want to do it cheap b/c my sub is only a single range, I'm saving for a dual range. Do you know if it's hard to fix a broken turbo? Or how much to get them fixed? Are they somewhat easy to find ?
Thanks- Thanks for the info. guys !! Subaru Rx springs? and then what type of shocks do you guys like to run? Probably find @ a junkyard huh?
