abanic1
Everything posted by abanic1
  1. Hello everyone I also read that thread a few weeks ago becouse I have the same hard start problem when the car was hot (cleaning wasnt a reason-problem was about two years old) . I replaced all 4 injectors and I solved problem And now I am asking you guys if there is any chance to test which of the old 4 injecotrs was faulty before I give back old injectors to friend (I think the one is problem and not 4 of them). My friend also have that problem and I think if there is any chance to test at home which injector is faulty with random disconnecting the injector electric. And see if car will start faster without the faulty injector which have chance to fload the engine.
  2. Thank you for your help. So now I must find a coolant temperature sensor and I will try if will help. Have a nice day
  3. When I start the engine rpm goes on 1300 rpm and the usualy back to zero and motor dies. If I touch throtlle for second and leave then car works OK. The fuel is OK, sparks are new. Only trouble code 35 I get 1 month ago and I replaced Canister purge solenoid... But the problem is still there.
  4. I am new here and I have question about my 1992 legacy 2.0 4×4 (european market ). Every time when i want to start my legacy at morning (cold start), car start without a problem but after a few seconds die? - but if I step a little on throtle is fine. The same problem I had on may old legacy 2.0 GL 2WD. There is no Check engine light signal. Thank you for your answer
  5. I want to discous about this problem, beacouse this might be a problem of cars when reach about 235k - 245k kilometres (miles about ?). But this problem is not so big becouse every time when I start my subi I step on throtle to 2000 or 2200 RPM - then works perfectly. I heard that you dont have any 2.0 ordinary subi-s in America without turbos. I am also intersted in your fuel comsumption which is? I dont know what time is in your country but I am going to sleep now.
  6. I am new here and I have question about my 1992 legacy 2.0 4×4 (european market ). Every time when i want to start my legacy at morning (cold start), car start without a problem but after a few seconds die ? - but if I step a little on throtle is fine. The same problem I had on may old legacy 2.0 GL 2WD. There is no Check engine light - blinking. Thank you for your answer
