Location
Durham
Vehicles
'86 GL 10 turbo 4wd Wagon
DasWaff's Achievements
Advanced Member (3/11)
10
hey. hows it going, im kinda local... anyway i was wondering if you or any other forum members wana try meet up at effendal pass in tahuya o.r.v. over the weekend?
Well I wasn't careful enough in this surprising February cold snap and in trying to trace a coolant leak I let the anti-freeze get too dilute. Engine froze solid and cracked the block. Sadly I do not have the time to do another engine swap. So... her remains are now on sale in the market place. '86 GL-10. Thanks a bunch to everyone here who helped me keep her running for so long. DW http://www.ultimatesubaru.org/forum/showthread.php?t=71516
When you pull the oil pan you may want to soak the bolts in mineral spirits, it will remove any gunk which has built up on the under side of the bolt head. At 4 ftlb you really want a clean fit between engine, gasket, pan, and bolts. Also (I know, I'm repeating myself) clean the pickup screen while you have the pan off. A spare oil pan is a great thing to have... It can be cleaned and prepped in advance, then swapped. The old one can then be cleaned at your leisure, especially true where the gasket has become one with the pan. You may also want to replace the O ring on the dipstick tube while you have it out when you pull the T belt covers. It can not only leak a surprising amount of oil out but as GD noted elsewhere, allow air to leak in to the 'sealed' system too. If the tube and dipstick are nicely sealed the engine should run slightly rougher at warm idle when you pull the dipstick up. As for your landlady... ??!! Maybe a dart gun and Estrogen... Good Luck, DW
Why subaru's are retired...
DasWaff replied to zyewdall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
'87 DL wagon, drove it 3 years, became a Subaru junkie, but had to quit driving it because of the insane rust... But I traded what was left (mostly the sweet spfi engine and cabin electricals) for my current GL-10 wagon w/dead engine plus a working EA82t with 220K on it. Bought a wrecked GL-10 for parts, it was crushed soon after. I imagine I'll still be here when the topics are distilling your own fuel, electric conversion, and modifying your wagon to be horse drawn. DW -
After the "before" but before the "after" PICS
DasWaff replied to DasWaff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, the real question is more like whats my build budget... Gonna hit a couple of the zillions of body shops around here and try to get her a fresh coat of paint. The wagon is my work 'truck' and I'd like to keep it as rust free as possible. Also going to try to figure out what can be done about the fine cracks in the rear black corner wraps, if anything. Actually I didn't know it had a digi when I got it. I do still prefer the analog gauges but I have adjusted and become kinda fond of the amber digi, especially the turbo animation, and it draws a lot of comments from the folks who ride in it. With only the posted photos to go on, your wagon definitely seems lighter and redder than mine. I've never seen the same brown as mine in person, but I have seen a couple of pics of Subies that color. I'm hoping the shop can match that metal flake brown, I'd like to keep it. You would think it wouldn't show dirt but all the red mud around here stands right out. I need to find a couple of trim bits, I have the original grill and an '87 grill, and I'm going to leave the gutter trim off. Biggest problems inside are a badly sagging head liner and a worn back seat. I ran a bunch of the seat, cockpit, and dash plastic through the dishwasher while I was working on the electrics and it came out great. We'll see how it goes... DW -
Notice I did not say "my boxer"... DW
As I understand it, harmonic balancer is a shock mounted crankshaft pulley that compensates for the stresses caused by the (unequal) angle(s) at which power strokes exert force on the crankshaft. One angle in an inline or slant, two in a 'V' configuration. Since the flat four power strokes are inherently 180 degrees apart the crankshaft sees equal opposing forces which eliminates the need for the harmonic balancer. A smooth running boxer looks motionless at idle because of the great balance, probably could pass the old Duesenberg nickel standing on edge trick.
I dunno... Seems to me its should read more like,"Welcome to hell... Here is your Yugo/Fiat/Plymouth Horizon/AMC Pacer/Skoda." Unless of course he has to ride in the jump seat.
Glad it wasn't worse, and that both of you are still 'road worthy' Hope the rest of the pic post we see from you are all upgrades! DW
All, well here is the wagon after all the engine and elec work is completed . Now time for a bit of cosmetic work. But I wanted you all to see the beast. Thanks to everyone up here who helped me get this far!! And a special thanks to Ed Rachner who went well out of his way to help me with my Pug wheel madness. http://www.ultimatesubaru.org/photos/showgallery.php?cat=500&ppuser=18065 So next is a trip to DMV, then some trim work etc. I'll post more pics later DasWaff btw, the silver LeSabre in the background is my Mother in law's...
http://www.ultimatesubaru.org/photos/showphoto.php?photo=13396&cat=500 Mine won't show the lowest temp bar, and since I snapped these right after starting you cannot see temp indicator. Amber '86 Digi Dash DW
oil pressure sending unit location on EA82T
I know, but as I said this isn't the original engine... might get lucky:) I always thought is was "O.I.L. Ohhell Install Longblock" DW -
Thanks I'll have a look and see if I need the sender, it would be nice/easier if this motor has one... and thanks for the after market info too. DW -
Window/door adjustment ??, guru help appreciated
DasWaff replied to daeron's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Latch can also get debris inside... from things like backing up with the door open through the underbrush, etc... not that anyone here would do such a thing... If the striker alignment is good try some grease on the latch too. DW
