nathan_d
Vehicles
82' wagon. 86' brat
nathan_d's Achievements
Advanced Member (3/11)
10
so i desperately need help with this strut on my brat as i need the brat out of my friends shop this weekend... I put a jack under the strut and jack it up putting the cars weight on it and no compression. i put spring compressers on the springs and it just compresses the springs and if i put them on the top and bottom it just bends the sturt at the top, bottom or middle. Is my strut completely shot??? If it is, is there any way to get it back on anyways and would it be safe to drive for a short distance???? THANKS! p.s. yes i pounded the bump out to clear room for the strut
if it is lifting the body that should be enough weight to compress the strut right? is there any other way to pull the ball joint in?
quite a ways, what worries me though is my strut on this side is not compressing at all where as the one on the other side actually compressed?
I was using a floor jack and it was just lifting the whole body off of the jack stands...
so i had everything on my brat for my lift and am putting the lower ball joint back in and the strut on the driver side of my brat will not compress... any ideas? do i just need to bite the bullet and buy a set of new ones? or did it spin and lock or something?
thanks!
Which way do the strut blocks face??????????? http://www.ultimatesubaru.org/photos/showphoto.php?photo=14563&cat=500&ppuser=16418&sl=m
ya it was on flat surface but should it be such a big fluxation of oil just in the valve train if i have just turn it off?
ok so this may be a really dumb or obvious question but.... I have an 82 Gl wagon with a EA81 and if i check the oil level while it the engine is cool and has not been driven in awhile it shows full but if i check it at the gas station it shows it needs a quart Which one do i go off of??? I am running synthetic oil
ALRIGHT FINALLY SOME PICS!!!!!!! WHAT DO U THINK???? http://www.ultimatesubaru.org/photos/showphoto.php?photo=15519&size=big&cat=recent
So over the last couple days I have putting a 5" lift on my 86' brat and it is coming along nicely. The back is done except for the brakes and the shocks. I have the front lowered and ready to block it. Where the heck does this anti-pitch adapter go? &limit=recent[/url]
Fixed! just said the heck with it and ran a new wire from the fuse box to the switch
Alright so after further testing.... I have no juice coming into the switch. When i run a wire straight to the switch the brakes work fine. So i guess the question is where the heck does the wire going into the switch come from?
