84gl
Everything posted by 84gl
Because I have kept the parts over the years I've owned 2 rusted out 84 turbo wagons. and the touring wagon was a stock turbo car I got out of FL. with a thrown rod so, I swooped in a xt mpfi N/A motor and ecm 3 years ago I wrote a thread on It. I just want to know any one else thoughts about it. The motor will be a 86 hydro low mile short block with 84 turbo heads and intake It look like all the sensers on the intake will switch for the ones 89 turbo intake oh GD the ejs I've owned were almost new mile cars 2003 up and when I had them they were under warranty the first one happen while I was in college 04 and was working at a subaru dealer at the time it was a 03 wrx wagon I take better care of my fleet of cars than most people you will find for that matter I've been drive my rx turbo for 11 years I know what I am doing right now I own 7 subarus all running from a 76 FE coupe to a 91 xt6 and thats not counting the almost 30 rust buckets I have on my farm thats what normally kills subarus here in the southeast they were cheap 4wds were drove in salt, snow, mud, dirt roads and NEVER WASHED my family has own subarus since 1974 I know how to fit them the new ones just aren't as good as the 70s a 80s
has anyone done this before I am thinking about building a motor for our touring wagon which will be a hydro ea81 WITH TURBO HEADS so can I use the FI the wagon already has I know the injectors are in the heads on the ea81 and in the intake on the ea82 but using the ea81 intake and changing over the senors and engine harness will it work? I'm tried of the ea82t and have all the parts I think to build the EA81 I am asking about and I AM NOT EJING THIS THING OK SO DON'T ASK I have luck out ej cars owned five and have all leaved me stranded water pumps locked, tbelts,bad heads,crank keyways its ea81 mpfi or ea81 spfi
you have gen 2 brat which was made from 82-87 US and 82-94? every where else a first gen brat is 77-81 they are stock 4sd S/r ea 71s with center mount starters but 81 brats have 4sd D/r with a ea81
I have a wrecked xt6 with 37,000 miles I got for almost free thats why i was thinking of the swap but if i have to cut the car up it is not going to happen our touring wagon is just too nice for that so i guess i'll just rebuilted the Ea82 xt mpfi non turbo motor i have to run as strong i can
what will it take to do the swap i don't want to cut the car up so if that's involed i am not going to do it
it runs when gas is dumped in but i think we figured it out nasty plugs at the injectors now it sounds like its running on 2 cyl. when i crank it thanks
First off its been sitting for about ten years so we cleaned the tank out changed the fuel pump and fliters new battery and so on still no go it has fire is in time has fuel to the fuel rail 13.08 volts on both pins on the injectors but no run oh the led light is not flashing on the ecm i can't figure out why but the fuel pump still cycles with the ing. switch on could the ecm be bad if so what years will interchange? 85,86 turbo maybe
i've done every thing i can think of to my brat to fix this the only this i have not done is buy a new iav
pics of some of my other soobs
busted strut one side will do it it happened to me a couple of years ago
maybe your right i don't know but its odd thats all i'm saying by the way the center lamp does work and the winch is the 5000 pound northern tool has with a home made remote control. oh for the record if any one wants to keep a stockish look the stock bumper ends fit the 4in channel bumpers i made that way the local law don't write you up on bumper laws in TN when is finished. The bull bar and roll bars are moded copies of the stock ones i made their made from 2 sc40 cold roll for the bull bar and 3in sc40 for the roll bar if any one needs help in my area make their own i 'll be gald to help
non turbo 5spd d/r with a custum made front ring gear (made it at work on a hc160 mazka mill) with a mod. lsd pack from a 300zx nissan the rear is all subaru r160 from a outback i think with rx lsd in it so,the Lo range and all other gearing is the same
Maybe its a factory odd ball thats my kind of luck anyway. the reason I'm going to keep i this round is its almost rust free and thats rare on the east coast
its a 82 orginal from AZ and is GL the center lamp is orginal all the wiring is and factory the title says its a 82 the vins all match body dash door jam i've owned this one two times now and for almost 5 years this time and i think i am going to keep it this time oh by the way it was a 4spd s/r when i first got it in 2001 ps the power steering is my doing from a rotted out Turbo wagon in dogtown junkyard castlewood va
Its has a gl dash oil press, volt,tach Crusie ps and had ac and everything every other brats got but Ttops don't know why it didn't get them but thats the way it is and no their not welded over i checked when i redone the head liner
Its a GL but its got a soild top So what do you think of years of work specs built EA 81 dyno @ 113hp 121tq spfi 5spd d/r 4.11 lsd both ends 4 in channel bumpers bull bar roll bar pugs rear disk brakes It just needs painted maybe this summer
SPFI from Automatic into Manual Trans?
84gl replied to coylethebarbarian's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes but i think you have loop or cross over the switch that was on auto shifter i had to but it depends on the donor car mine was a 89 gl-10 spfi 4eat 2wd with power seat belts and a diggy dash not the best donor but my brat runs fine away -
Old Subaru's from little Iceland
84gl replied to KristjanJohann's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would like to know more about the subaru van in you pics we didn't get them here By the way nice pics -
I want my EA81 to have HP! Anyone got links?
84gl replied to robert_the_sane's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have built two ea81s with delta 240 cams big valve heads 2.00&1.94 valves 11.5 to 1 comp. and spfi It dyno @ 113hp 126 pounds of torque it can be done its just not easy. Its took me long time and alot of work to do it. oh by the way I'm a Machinist SUBARU DUDE has rode in it -
I thought you sold your T wagon ?
If have 50% will I have the other half 2 rx 3doors 1 rx 4door 8 wagons 2 hatches one ejed and brat with a nuff parts laying around to build 10 more
1986 5spd d/r wagon all orginal and still running with 574,000 on it Home | Forum | USRM | Photos *** Ultimate Subaru Message Board Welcome, 84gl. You last visited: 01-11-2007 at 02:20 PM Private Messages: Unread 0, Total 19. User CP FAQ Members Calendar Search New Posts Mark Forums Read Open Buddy List Log Out ***My***Photos · My***Albums · My***Favorites Home · Search · Profile · Upload***Photos *** Home » Club Member Photos » 84gl · Slide Show · Next image » > >> Image001 Photo Details Poster: 84gl*** (see this users gallery) · Date: Sun March 13, 2005 · Filesize: 36.3kb · Additional Info Rating: 10.00 Add to Favorites · Report Photo · Print View Admin Options: Edit Photo ****** Delete Photo?****** *** Submit Powered by: PhotoPost PHP vB3 Enhanced Copyright 2005 All Enthusiast, Inc. All times are GMT -5. The time now is 01:14 PM. Contact Us - http://www.ultimatesubaru.org - Archive - Top Powered by vBulletin Version 3.5.3 Copyright ©2000 - 2007, Jelsoft Enterprises Ltd. Copyright © 2003 Ultimate Subaru Club, All Rights Reserved
EA81 compression, custom pistons, how much?
84gl replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i made the pistons in my ea81 they're all right with my set up but i think what help the most welding up the area head -
Another one bites the dust...
84gl replied to RenaissanceMan's topic in Historic Subaru Forum: 50's thru 70's
its steel fixable pull roof out and and get glass back in there a ride it use it as and offroader thats what i would do
