Everything posted by 84gl
max miles on a subaru?
84gl replied to Drazgoth's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 86 gl wagon has 563k on it any thats the orginal engine
Any differences in timing or carburation betwteen Auto and stick EA-81 engines?
no I think its 8btc on carb and 20btc on spfi,mpfi,turbo mpfi
Cleaning a very dirty engine.
go to the car wash and spay it down with the tire cleaner wait a few minutes and rinse that will get most of it
1987 AMC Eagle vs 1978 Subaru Brat
the brat all the way
Any trick to getting steel wheels off?
loose'n lugs go in circles works every time
Subaru Ram Power!
why go carb when one can go ea81t better base line to being with and more pontenal
why an EA?
their as tough if not tougher than most new trucks go better cheaper to run and keep running and are simple to work on
$250 For Piston Rings?!?!?!?!?!?!
240-270 sounds about right for rings oem is the only way to go i know the price seems high but think about it 2-3 years down the road when the cheap set breaks a oil ring and your back to square 1
ea82 carb gas mileage driving?
whats with your rigs my 3door with a mildy moded ea82 (heads shaved .040 delta 240 cams slightly bigger valves and port&polished) does fine on hills pulls good in 5th from 40mph to 105 (as fast as i've had it) and gets anywhere from 29 to 36 mpg in my driving. sorry maybe this is for wagons well then i think my wagon gets 21-26 mpg but it is a real slug and hasn't seen 70 for years burns oil has 90 pounds of comp. per cly. but, hay what do you think a car of its milage would run like but it still runs and thats the main thing (when driving it you have to have the state of mind i'll get there advently)
Turned 298K today...
I guess i need to watch mine i've just got 6000 more miles to go til 570,000 mark
Spare Parts for Road Trip
spare axle if the trip has any wheeling intended, basic hand tools, wire, 36mm shocket, breaker bar, GERBERs, oil, water for drinking or car, mre or 2,
what do you like about your suby?
everything if we don't we wouldn't own so, many
GOT MILES? how many do yall have on your subies
569,000 on my wagon which was all put on it by my family the only motor work thats has been done is a reseal @ 549,000 AND THAT WAS DUE TO THE HEAD GASKETS leaking oil
Ratio of running vs. non-running subarus
3 and all run and drive
Northeast Vintage Subaru Owners Club
so, this would include my 1980 1800 gl auto with 70,000 orginal miles that great finaly the east coast gets a club to and i'm going ot be at carlsie this year but i'll be in the 3 door
Pillar guages for EA82 cars?
I would like to know to if any one has done this and where to get the housing that fits
engine has a bog at low RPMs
its just the gauge or the sending unit
First MPG calculations in lifted brat
Ned's just letting it rust down and the longer it sits the beat and bagged up it gets the whole pass side rear quater is smashed in the rear glass is busted out it needs to be saved or there want be anything left of it
my wagon get 22-24 no matter how i drive it oh brad if you miss it so much go drag it out of the junk yard
1800 miles in a junkyard GL: comments & observations
hay but some of us have gotin tickets in their soobs so, their not that slow
Idea for a "readers' rides" type thing
nice one kelly
Soob-haulers?
car dolly and if its not the wagon broke down its my tow car
Thrown Rods?
I've never seen a subaru thow a rod or heard of one that did til snowmans and that was though this board so i would say that is very very rare for a subaru these are tough engines not like chevy dodge of ford which are by all rights junk i've never seen one of their motors last 150k without major work beleave me i use to work at a dealership on the other hand i have a subaru wagon i still drive with 563k on it and thats the origonal engine the only work thats been done to it is head gaskets and timing belts that not the ony hi milage subaru i've owned a 3 door i had a few years ago had 396k on it when i sold it and still run good but too me a low milage subaru is one with under 200k on it
cold engine hessitation
take the choke apart the round black unit that work the choke has a heating coil in it check to see if it is broken if is try to solder a heater rezister in its place works great on my 80 sedan
How dedicated are you?
well the wagon have my aunt bought new in 1986 so, its part of the family anyway two years ago I heard she was going to have it crushed because unknown to me the car was wrecked in 1999 (bent frame etc and had 495,000 on it ) and she said it was not fixable. well the car was 100 miles away i drove my 80 sedan up it see how bad it was so after looking it over i bought it for $100 and started to work try to get it started no go the feul pump was bad from setting so i drive back home get a spare feul pump fenders bumper etc and go back get it running clean the rats nests out put good head lights in and leave for home now the only brakes the car has is the e brake no tail lights and hasn't been dove in four years a still makes it home
