bluesbug
Contact Methods
Website URL
http://
Location
Levelland,Texas
bluesbug's Achievements
Member (2/11)
10
My 60 VW panel van has an EA81 engine and it fit EASILY in the engine compartment,and I used the KEP adapter. The radiator, a stock 80's suby was put in front of the engine cover,on hinges so it can tilt out, and a modified engine cover was installed.It has 2 cooling fans(electric) that pull air in from the back.It cools fine,but restricts engine access somewhat. Look at my other posts for pix and more info.
Thanks, I love the yellow/gray combo on vw busses,but my second choice was yellow/white.Looking foreward to the pix of your bus.
total cost about 1200. weber hooked up to stock throttle cable.no xmember reqd. pix on some of my previous posts,feel free to paste em here. bluesbug
I've got an EA-81 in a 61 split window panel bus,and it's great. Progressive weber,custom exaust,kennedy adapter,and suby dual fan radiator in the rear sucking in.Cools great and plenty of ponies for the stock tranny w/reduction boxes.Very straightforeward swap and easy to work on too. bluesbug
Check out the latest hot vw's magazine.Nice wrx powered Karmann Ghia.No info on radiator mounting etc.. but one way cool car!
My new project, Air Cooled Vanagon to Subaru EJ22 Conversion
bluesbug replied to ShawnW's topic in Subaru Transplants
Dont give up! You'll get there.We're dying for an update. -
71 bug with a EA81 subaru engine (carb problems)
bluesbug replied to Will the Thrill's topic in Subaru Transplants
I agree . Go with the weber.. The intake and carb can be found in the marketplace sxn..The motor is so much cleaner and easier to work on and the power increase is substantial. -
Shawn, You might try an electric temp guage.Mine in my EA81 powered 61 vw bus works pretty well and they can be han on ebxx pretty reasonably. nice project -
EA81 newby question- SPFI instead of carb?
bluesbug replied to dansvans's topic in Subaru Transplants
Put a wanted to buy add on the marketplace on this site.You can probably find a good used carb/manifold.Search in the older suby area for WEBER and get addl info....For my exaust I cut off the two pipes about a foot down from where they bolt on the engine,and later had a muffler shop add a Y pipe,a flange,a turbo muffler,a u turn and a side exit with a chrome tip.It looks and sounds great and was $150 well spent.. -
I highly recommend going with the weber carb conversion.My 61 panel van has an EA-81 weber setup and the power band is great.Easy to work on too! Bluesbug -
Havent had a chance to road test much yet,but the power band is excellent.Got wheels powder coated and new tires on and they look niiice.All windows are now in,though there aren't many as it is a panel van.
Thanks guys.The Subybus may travel to Dallas(Ennis) in May for the VW show.Someday there may be a 300HP bus in my future but not for a while...
Well the bus finally got some paint on her and we've been trying to finish up the outside.. Right now it's still lacking a windshield, engine cover, tires&wheels, exhaust and a few odds and ends.. Pictures are in the gallery and hopefully in this post. Thanks for all the positive comments and feedback, keep em comin!
The adapter bolts to the engine and the whole assy then bolts to the transaxle just like an engine bolts in on any beetle or other air cooled VW.I built a jack cradle to avoid the oil pan while jacking the motor in place. BTW the subybus is now painted and going back together,and PIX will be posted soon.
The radiator is a stock 82 suby that cost $129/w a lifetime warranty.Top hose is extra long to facilitate opening.Fans are both stock 80's suby and have plenty of clearance. Tranny supports engine fine,but a xmember could be fabbed easily enough if needed. Now if it would just warm up so I could finish painting my subybus!
