About cubastreet
- Birthday 06/08/1976
Location
Wellington
Interests
Espresso,Engineering,Electronics
Occupation
Espresso Tech
Vehicles
81 Brumby
cubastreet's Achievements
Eat, Live, Breath Subaru (5/11)
21
Steering Wheel Hub Adapter - 79 GF
cubastreet replied to Cox Racing's topic in Historic Subaru Forum: 50's thru 70's
I have a momo boss kit in my brumby, don't know if it's still available though. -
best newage hybrid?
cubastreet replied to bluedotsnow's topic in BRZ and its Sister the Scion FRS/Toyota GT86
Amazing car the 918, but no longer in production. They made all 918 of them. -
In 9 years, the only thing that's threatened to leave me stranded was a burst heater hose. A fanbelt and spare ignition supplies, plus a bottle of oil and water and a few tools would be wise. Also, a multimeter and a length of wire. That reminds me, my ignition wiring failed once and I had to hotwire the car by hooking the ignition coil to the battery with said bit of wire. I've done a lot of mods over the years, but the best by far was installing a pair of heated leather seats from my mate's Ford Mondeo...
ea81 dual port preview
cubastreet replied to cubastreet's topic in Historic Subaru Forum: 50's thru 70's
It's mild steel. -
Just need to make carb mounts, linkages, some sort of filters, and something for the thermostat/xover pipe. -
Yeah progress has been pretty slow on this one - life gets in the way. My valve stem seals are really bad now, I leave a cloud of smoke at the bottom of every hill. That gives me some motivation to get in with it. I'm angling the carbs backwards so I won't have to relocate the battery. Should look and sound pretty cool and hopefully have a bit more get up and go too. -
Any of these have airbags?
cubastreet replied to comatosellama's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just don't show them a line graph showing how the number of cars on the roads has been increasing but the number of road deaths has been decreasing... (I drive old cars and ride motorbikes so I'm certainly not saying don't buy an old car, but the safety benefit of new cars isn't something you can deny) -
upgraded headlight wiring
cubastreet replied to Demon Brat's topic in Historic Subaru Forum: 50's thru 70's
The yellow plug goes into the headlight socket nearest the battery, and the two green sockets plug into the headlights. The red wire goes to the battery +ve and the black wires go to the car chassis. -
I used this: http://www.dx.com/p/car-headlight-h4-plug-fog-light-socket-set-black-255413 It only does two headlights but the relays were big enough to handle splicing in two more sockets for the other bulbs. -
EA81 rebuild with SPFI manifold 38/38 carb
cubastreet replied to tweety's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ea81 ports and intake manifolds are 35mm. You can fit a larger manifold but the ports in the heads will still be 35mm. There are also three sharp right angle bends inside the heads to kill flow. This is why the 32/36 doesn't have a higher top speed than the standard Hitachi. As you know, the dgas is 2x38 and it's synchronous. It may feel like it has more power low down because it won't take much throttle opening to get full flow through the ports. If you tune it right, you should get the same fuel economy at cruising speed, but you'll have to be very gentle on the throttle to get good economy around town. Airflow through the venturis will be very low at low engine speed, which may cause poor fuel atomisation. This would cause a flat spot when you floor it unless you inject a good dose of fuel through the accelerator pump; another potential for poor stop/start economy. Personally I think it's too much carb for 35mms ports, the 32/36 flows enough for at least 120hp. I'm not going to say don't do it though. Nothing ventured, nothing gained etc. But if you find you get terrible economy around town, I'd suggest swapping the carb for a 32/36. -
I've dailied a gen 1 for most of the last 8 years. Most of the time it's ok but it doesn't have much power for overtaking when I get stuck behind a slow car on nz's winding hilly roads
Hello moderators - can we clean house of ....
cubastreet replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
I think you may have shipped a couple to new Zealand last time, do you remember how much that cost?
