mdjdc
Everything posted by mdjdc
If the roll connector is failing, it has to be replaced. It controls the horn and the blinkers. It is going to completely fail. Replacement isn't all that difficult. You remove the steering wheel and the column surrlund and the connector is right there. I may even have one in my store house of parts. I can look this weekend
Sounds like you have a bad roll connector in the steering column.
Are you letting the car sit for long periods without running it? Todays gas has ethanol in it and the gas breaks down rapidly. Sounds like you are getting bad gas and it has a higher flash point than normal. Once the car actually starts it will keep running and I am sure that after 300 miles you have to gas up again. Just run the car every other day for about 15 minutes and fill the car when needed and you may fix the problem.
Tire Howl
mdjdc replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
For what it is worht, I have BF Goodrich Tratctio TA's on my 99 forester and they do howl someon the highway. Worse on some types of pavement, bt they have a more agressive tread pattern and that is what I wanted. Overall I like them except for the fact that they are a rotational tire. Didn't know that when I bought them. Got them for about 100 bucks off a car that was being parted out and they were brand new. -
Tire Howl
Even at 150 a piece, that is still a far cry from 600 for the viscous coupling and the labor to install it, or the parts and labor to fix the auto trans when it starts binding up. That can also be a very dangerous proposition when the tranny binds in bad weather and you lose traction. -
Tire Howl
And the two extra tires are about 150. Just not worth the trouble. Espescially if the bind comes on in the winter. It sucks to loose traction on the snow in a turn. -
Tire Howl
From the original posters second post, I don't think he is going to listen. Personally, I learned from an Outback that I bought from a friend. He was in the habit of only changing two tires at a time (front or back) and within a year I had a bad viscous coupling and I had to replace the trans. It just isn't worth the trouble to save a little bit now and have a much bigger bill down the road. Just my 2 cents -
I don't think you filled her properly. You said that you started the car and then filled her until there was steam coming out of the vent cap. You need to fill the car when it is not running. Put her on an incline with the nose up. Take out the vent cap and fill her until you antifreeze coming out of the vent, then replace the vent and start the car. Continue replacing fuid as it goes down and the thermostat finally opens up. Then you ar full. Put a new cap on her. They are cheap and then take her for a drive. If she overheats, check the flow of the rad, but they rerely go bad. My feeling is, that if she continues to overheat, you need to doa headgasket job. Don't keep running her as you will run the risk of damaging the rod bearings.
I just fixed the very same problem for a friend of mine. The switch is the problem. It is really east to replace and doesn't cost all that much. You can do the replacement in about 1/2 hour. Switched weat out and yours has some age on it. If you want a known good one, I can grab one off my spare tranny, but you should be able to get a new one for less than 50.00. Personally, I would put a new one in.
As far as the phase 1 engines are concerned, the new gasket is either a 4 or 5 layer design. I am scared of the viton coating as Subaru recomends no coating on their gaskets. Maybe this is the way to go on the phase2 motors, but for the phase 1, I wiould still use the Subaru gaskets. Just my 2 cents.
Does your trans light come on at all at start up? I'm thinking that the light isn't working and that you may, infact, be having a Duty C problem. I have a friend that had a very similar situation and it turned out that the PO had removed several of the dash bulbs to hide problems when he sold the car.
I have a hood and one fender. I think the fender is the drivers side. Shipping might be cost prohibitive, but I wanted to put it out ther for you. Mike
They discharged the A/C system to do the HG's? That was a waste of time and money. You are going to pay thru the nose for a recharge of the system and the compressor could have been laid over to the side to get it out of the way. If you went to a shop, I would tell them to recharge the system for free, since it didn't have to be discharged in the first place. As for the fans, I agree, look at the entire loom under the rad and see if any other wires are damaged. critters aren't usually very discerning and they often get several wires. I had it happen in my daughter's car. What a mess the little rodent made. Good luck
Matt: the ;ulley icludes the bracket. It is ready to mount to the engine and go.
Mike
Please PM me, I get lost in the user proflie messages.
matt:
I have the idler pulley and it includes the pulley and the mounting bracket. It is a complete unit that you can just install on the motor and go.
Mike
Make sure that you have the crank sprocket set for putting in a new timing belt. Hold the crank still or use the screw sriver in the flex plate and pop the cam bolts off. I say POP because if you give the bolts a sudden POP they will break loose alot easier than if you use steady pressure. Don't be surprized if the cam sprocket jumps on the timing belt. Another way that I have used is to remove the timing belt and put it on the side. Get a lenght of old timing belt and wrap it around both cam prockets. Use a vise grip to get the belt tight and then work on the bolts. This way, you have no chance of damaging a new timing belt. If you need an old belt for the job let me know and I will mail you one.
I have seen this before. The car probably had terrible torque bind that was never addressed and as a result the rear drive drum broke off the shaft. I had one that was likw that. I replaced the shaft with the drum on it and set the rear housing withe the clutches back on the drum and VIOLA the problem was fixed. This is a problem that can be addresses with the car up on ramps in the driveway.
