mdjdc
Everything posted by mdjdc
You didn't mention if the system needed to be rebuilt due to having deployed. If the airbags were deployed you cando all the diagnostics in the world and you will STILL have to replace the main control unit. They are a one shot and throw it away unit. They do not have a reset. What type of repair work was done?
I see some oil on the filter and that tells me that there is a leak in the front of the engine. That can easily get oil blown back and on to the exhaust. Get the car up on ramps and look at the back side of the oil pan. If you see that it is wet with oil up near the mating surface, you most likey have the seperator plate issue. Unless you are doing the job yourself, it is going to be an expensive repair. Engine removal is required and that gets pricey. If yo do it yourself, get the updated plate from Subaru and the new bolts to go with it. Use a good RTV and it will be done. Check the rear main for wetness. If it is dry, LEAVE IT ALONE!!! Then fix the fromt leaks and you should be good to go.
You more than likely, have a leak of the oil seperator plate. That is on the back of the engine and requires removal of the engine for repair. It could be the rear main, but I doubt it. The front could be the front main or the cam seals. A common leak is at the valve covers. If you really want to fix it right, pull the engine and do a reaseal of the major gaskets. Not fun, but not that bad either. A weekend project. If the leak isn't that bad you can build a diverter to keep the oil off the exhaust. I worked on a car that had one on it and the guy's father had made it out of a soda can and bolted it on the front of the engine crossmember to keep the oil from working it's way onto the CAT. Have fun
I am willing to bet the store that the code you are getting is for catalytic inefficiency. You will NEVER fix that without replacing the cats with subaru cats or using the sntifouler work around. The cat is not bad just not working perfectly. I had the same situation and used an aftermarket cat. The coed went away for 3 months and then returned. What a waste of money. I even replaced both O2 sensors and the coed still came back. A master mechanic (subie) told me that it's a very common problem with all the crappy gas out there. He said the subie cats are much more robust but even he wouldn't replace them for what subaru wants. He told me to just deal with the CEL and check the codes every so often to see if a new one popped up. Good Luck
ea82 auto tranny to 5 speed d/r swap
mdjdc replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did this not too long ago with my daughter for her build. Very straight forward and the shifter is plug and play also. All of the bolt holes for the shifter boot even line up. She runs great. The only hiccup we had was a problem with the kick down relay circuit. When she would depress the gas pedal too hard the fuse would blow. We ended up finding out which wire went to the computer and cutting it and the problem went away, but now she has a constant CEL. Guess we'll just have to live with that. Good luck -
Remember, He is in New York and it is liable to be a bit more expensive. I can call my sister and find out the name of her mechanic. He is very reasonable and very trustworthy. He works on the subs I built for her and my nephew and he likes them although I didn't leave him much to work on. If you want to take a weekend trip, I can do the job for you, but then you will have the expense of gas and tolls. Down here it is about 200 per side plus parts, so not a real bad job, but not cheap either. If I had a set of hubs I would get them for you and ship them up, but I just got rid of the last set I had. I can look at the local JY if you want.
Just bought a 91 loyale 5spd 4wd!
mdjdc replied to maozebong's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've got the ecu for you. Make me an offer and I can get it boxed and shipped to you. Mike -
How do I remove EA82 key tumbler?
mdjdc replied to hooziewhatsit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You will notice that there is a little indent next to the hole. Put a sharp punch in there and the pin can be pryed out. Kind of a pain when the ignition is still in the car, but doable. -
You have to actually pull the pins out. They only go in on the newer generation cars. Makes taking the tumbler ou a real PITA -
I will look at what I have and get back with you later. Hopefully today, but definitely tomorrow. Have you done the fuel check? You really need to do that so that you don't put in an ECU and find out that you have a bad pump. Try using brake cleaner into the intake and see if the car starts, if it does, you have a fuel issue, if not then fall back on the ECU. I will be in touch. Mike -
In order to check the fuel pump, you need to pull the line off the fuel filter up under the hood. Crank the engine and the fuel should shoot out of the filter over the bumper on out. you may want to put a small hose on the filter so you can direct the fuel away from the engine bay. There should be a strong stream when you are cranking the motor. If not the pump is bad or you have a bad pump relay. The relays don't go that often though. -
Get the numbers off your ecu. I probably have one.
