mdjdc
Everything posted by mdjdc
  1. K&N filters come precharged. If the filter is white then ithas no oil on it. If it is red, then it is charged. EVERY display I have seen the filter is charged. Just the idea that it would have less air flow is blatant false advertising and I am sure they would have been sued already. I think they didn't want you to double charge the filter.
  2. The one I fixed was broken for some time before I was able to fix it. I didn't realize what the problem was until I actually got into it. Several hundred miles won't be a problem.
  3. Just swap in the parts off your old tranny. If th AWD was working fine then you won't have any issues. A quick and simple fix. A few hours and you are done. You should be fine driving the car for a few days. The onw I fixed had been broken for a good while when I got into it and it is still running fine today over a year later.
  4. Pull the distributor cap and mark the position of the rotor. Bump the ignition and see if the rotor is turning. Pull the fuel line from the filter and see if the pump is pushing fuel. Today's gas sucks and having it sit for six months may have locked up the pump. I'm not sure if lack of fule will stop the spark, but I would definitely check for fuel. I just did a friends car and replaced the pump. It started right up, but after 24 hours the pump was locked due to the fuel. I rapped on it and it started working again. Drained the tank and filled with new fuel and no problems any more. Check all of the fuses and the fusable links. Listen to the advice on the board or you will spend a lot of time chasing ghosts and getting frustrated. Good luck
  5. If you decide not to fix her and you have the high rise center console, I would love to have it. Just asking before anyone else does. Personally, I hope she is fixed and back on the road soon. Mike
  6. You can do it the right way. Just lift the car and drop the rear cross member. You may have to drop the rear of the tank, but you do not have to detach any lines or plugs, not even to drop the cross member. Sqirm the new line into place and atttach it to the junction bloc and you are done. If you want good used preformed lines with the junction block, I have them. let me know if you are interested. If you fix it right the first time you will be more comfortable and safer. I, personally, so not like rigging brakes. I want them the way they were designed.
  7. Nipper: If you really want to replace the cable, I have a good ne on my parts car and I have a good set of the shoes too. Let me know if you have any interest in the parts I have. Mike
  8. The clunk you heard could very well have been the transfer clutch basket shearing off the shaft. I had a car do that and since there was no power to the rear wheels, there was no torque bind. If I were you, I would dig into the extension housing and look at the parts. I would want to know what I was dealing with, just so as not to damage a good tranny. The entire process tokk me 2.5 hours and that was on jack stands with manual tools. Good Luck
  9. I have used K&N filters on my subies for nearly 15 years and I have never gotten a code for the MAF. The filter requires good cleaning and oiling to specs. Over oiling will lead to fouling of the MAF. I have enjoyed the improvement in performance and fuel mileage. I'm not endorsing the filter over others, just fiving my experience. It really helped with performance with my EA82 vehicles and I have continued to use them with my new gen cars. If they were contributing to engine breakdown, I don't think they would still be in business, nor do I think that race cars would be equipped with them. When you look at the comparison of the two oiled filters in the test, you must attribute some of the color to the oil. The secondary filter was right atop the primary and some of the oil is going to aresol onto the secondary filter, leading to a darker color. In the old days oil bath filters were the norm and only discarded due to inconvience. Just my 2 cents
  10. Are you saying 20 plus shipping or shipped? I can pick up the box tomorrow, but it is a big part. Let me get a shipping quote tomorrow. Please use a private message. It is much easier to track the conversation than using a profile message.
    Thanks
    Mike
  11. I need your zip for a shipping quote.
  12. What is your zip so I can get a shipping quote.
  13. The easiest way to get at the plugs is to unbolt one of the motor mounts and jack up that side of the motor. You will then be able to get your socket in there for removel and reinstallation. Not a fun job, so use the good NGK platinium plugs. They are rated for 100K so you won't have to do them for some time.
  14. Nice car. The speedo issueis a problem with one of the contacts. Open up the back of the speedo and you will find one of the solder joints bad. Just resolder it and you are good to go. One of my friends had the same issue and she fixed it very easily. As far as the gas guage goes, try the techron. If that doesn't work let me know and I can send you the secondary sender out of one of my parts cars. Known good. Mike
  15. How's 50.00 plus shipping? What do you have to barter?
  16. I have one that is free spinning. Let me know if you want it.
  17. I am asking these questions now, but I haven't gotten the car yet. I am looking for an easier fix once I pick it up. Gary when you say the inhibitor switch, do you mean the neutrl safety switch, or is it different? I figure it might be an electrical problem and that is why I posed the question and I appreciate the heads up. If anyone else has some suggestions please hit me with them.
  18. I have the opportunity to buy a 98 legacy with 130k on it for cheap. The issue is that it won't shift out of 1st gear. I am prepared to swap in another tranny, but I figured I'd check with you all to see if there is something I should check before jumping to the swap. Thanks Guys
  19. Use the SOHC gaskets and you will be fine. There is plenty of clearance and you will end up with a tad more compression. The engine I built was nice and peppy and my buddy is very happy with it. Be sure to rebuild the oil pump while you are there and you won't have to deal with it later.
  20. I used a DOHC block to build a SOHC motor for a friend of mine and it runs like a champ. Go for it and good Luck
  21. This is just me, but I would reseal the engine you have. I am more inclined to keep the car stock so that if I want to sell it it isn't a hassle explaining it to the new owner. Don't go the full rebuild, that is unnecessary. Get a set of Subaru HG's and all the seals necessary for the project, a water pump and timing kit. You can get the water pump and timing kit off ebay. Reseal the engine and be on your way. My thought is, that if the car is in such good shape, the owner probably didn't overheat it too bad. He/she was caring for the car very well and this probably sidelined the car due to concerns of total failure. I can routinely get the necessary parts for around 300 and then you just have your labor. Go for it and have some fun.
  22. You won't get a CEL unless the car runs for a certain amount of time. I have done the stupid and started without the MAF plujgged in and didn't get a CEL. Your MAF is a wire filament type and it may have been damaged a bit prior to cleaning and the apray just finished it off. Take it off and look at the filaments. See if they are broken, if so, then it will have to be replaced. My thinking is, if it was running before the cleaning, then something broke. You have already checked all of the hoses, so that is not the problem and your only other possibility is the MAF itself. I have a couple of them laying around, so let me know if you need one. Mike
  23. You need to google tire size calculator as your speedo is going to be off. The calculator will tell you by how much.
