mdjdc
Everything posted by mdjdc
I am working on a car for a friend and he has an issue where the airbag light is on and so is the ABS light. I know about the clockspring for the airbag and that may very well be what it is, but is there a way to trouble shoot these systems? If so, can someone instruct me on how to do so? Thanks guys
Just for information sake, I have been running K&N filters in my 2 forresters and outback or several years now. I have not had any problems with the filters or driveabilty due to MAF issues. I think the problem arises when people clean the filters and then over oil the filters. If the filter is properly maintained, there should be no problems
Hey guys: For some reason I was not getting my notifications that you had given me some help. Anyway, we finally figured out what it was. The car finally threw a code for the MAF and I replaced it and she hasn't had any problems since. Thank you so very much for all of your help. I am so glad that she now has a reliable car. Stalling out randomly is not a good thing for a new driver.
My daughter's best friend has a 96 legacy 2.2 and it has one issue that is driving me up a wall. The engine runs fine, but periodically it will just shut off. It doesn't sputter and die, it just shuts off. It will restart immediately. The car has had the cam and crank sensors and the computer replaced and the coil too. it is still doing it. It did have an aftermarket security system in it that I pulled out and today I am going to check all of the connections that were spliced in to see if there is a short somewhere. Does anyone have any suggestions or has had the same problem? I am going crazy trying to make this car run consistently. Thanks for any and all suggestions
The biggest problem you have is the purge valve control module. That malfunction will just kill your performance. You have one on order and I think that will fix a lot of your troubles. You can go and get the sea foam throttle body cleaner and follow the instructions for use. It is a lot easier than using the liquid and trying to pour it down any opening. You may have a bad throttle position sensor, but I think when you replace the purge valve control you will se the car run much better. Good luck on your trip back home.
I have a 96 Legacy outback with an automatic transmission problem. The car has 325k on the original trans and the situation is this: When the car is started in the morning it will go into gear, but it won't shift until it gets good and warmed up. Then it seems to shift okay. If the car is started and then warmed up the problem seems to be much less of an issue. I am thinking that this is the early stages of transmission failure, but I want some input from you guys. All suggestions and opinions are welcome. Thanks
Thanks guys. Turned out that he had a cracked intake boot and the IAC was sticking. Replaced both of those and now the car idles at 1000 rpm.
Thanks guys. Right now the coumputer is not throwing any codes. I will look at all the obvious things first and I will clean the throttle body.
I have a friend whose daughter has a 90 loyale and it seems to have a constant high idle. he says that the idle stays around 2000 all the time. I am going to look at it tomorrow and just wanted some suggestions as to possible causes. Any direction will help me gat it fixed faster. Thanks
I have a friend with a 2.5 DOHC in a 98 forester. I have available a 99 2.5 SOHC motor. I know that the wiring harness is different, so that would have to be swapped over, but if I do that can the SOHC be dropped in the car? I was curious if the cam timing might be off and thought that I might be able to swap the cam off a 2.2, so I have wondered about that too. Any thoughts would be greatly appreciated.
I am building a forester for my daughter and it doesn't have cruise. I know how to install it, but I need to know if there is a difference between the cruise computer for a manual tranny and an automatic or are they interchangeable? If anyone has a cruise control system that they want to sell, please let me know.
A friend of mine who is a subie master mechanic said to oosen the axle nut and soak it with PB blaster. Then he said to take the car for a spirited ride around the bleck. He sait that always breaks the ones that are stubborn loose. I haven't tried it thugh. I am just going to replace the whole knuckle shen the time comes. I already know that my right side is frozen. Been rebooted on the car once already.
I have two 92 ej22 engines that run really well. The question I have is, can the harness from a newer 22 or a 2.5 be swapped onto that motor so that I can drop the engine into a 97 outback? Just curious. It looks like it is doable, but I wanted to see if anyone has done it. I have several harnesses, so that is not an issue for me. Thanks in advance. Mike
