Everything posted by mdjdc
2.2 swap into an outback
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOkay try to be a little easier on this old guy. I didn't put the year and you were both correct. Thanks
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDave: I was thinking that the 95 auto was the right one, but I couldn't remember. Now all I have to do is find one. Not too many in the JY's down here right now. Thanks for the info.
I have tried several searches and I come up with "no matches". What are the best years for a direct fit 2.2 swap into a 2.5 car? I can't remember what the range of years is. Thanks guys
Werid noise. video.
mdjdc replied to Suba_GL_87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI initially said that it was a spun bearing and I stand by that. The hydrolock is the death of the engine. You probably bent a connecting rod at the same time. Let us know what you find, but that block is now a paperweight.
Werid noise. video.
mdjdc replied to Suba_GL_87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDude: If you are referring to the knocking sound, you have a spun bearing. Sorry for the bad news, but it is only going to get worse.
99 Forrester cruise control problem
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat works. Thanks
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat you are describing is exactly what I was planning on doing. You saved me BIG TIME. Stupid little piece of plastic. Hope subaru has some in stock.
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry man, credit should be given to you. I just went by the last post I remembered. My bad and thank you very much for the help. It was the first place I lloked and you saved me alot of digging into the other parts. I really wouldn't have looked there first without some prompting. Thanks again
HG Replacement Help
mdjdc replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat definitely sounds like valve train noise to me too. I had this happen once after a hg job and I am meticulous about getting the buckets into the exact same hole they came out of. I would pull the valve covers and check the clearance of each and every one of the buckets. I am sure you are going to find that at least one of them is loose. you may also have one too tight due ot an inadvertant swap, so check them all. I know this sucks, but you will have to do it in order to fix the problem.
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThought I'd let you guys know. I looked at the forester (finally) and, Nipper, you were right. The plastic grommet had come off the clutch pedal. I am going to find another as the little prong that holds it on the pedal broke off. Hopefully, I can find one soon. I miss my cruise. Let me tell you, 1200 miles without it made me unhappy. Thanks for all of your suggestions.
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNipper: that is the first place I will look. Thanks
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Dave, I will check that out too. Iam planning on trying to tackel the issue this weekend.
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am hoping that it is not the clockspring. Those are expensive and hard to find used. I will hit the pedal switches first, then the steering wheel switch. Thanks for the input.
What is this under the glove box?
mdjdc replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have no idea why they decided to put the relay for the mirrors in that spot. I helped a friend put them in his forester and that was the only part that we forgot. That is how we found it and I know what that relay is.
mdjdc replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can tell you from experience, that's the heated mirror relay.
Okay guys, I need to help. I have a 99 Forester and this past weekend I had to drive from Richmond Virginia to Atlanta Georgia and when I got on the highway I found out that my cruise control no longer works. 1200 miles in three days with no cruise, I was not a happy camper. I am getting no check engine light, no ABS light, my horn works fine and my blinker signals work fine. I know that the roll connector can cause the cruise control to go out, however, I thought that the horn or blinker signals should be affected as well. When I push the button on the dash the cruise light comes on, so I don't think the problem is there. I'm thinking it's either the switch in the steering wheel, the cruise computer or the actuator under the hood. I guess what I'm asking is; where should I start looking, or does anyone have experience with an issue like this? One question I did come up with is; is there a relay that is actuated by the dashboard switch and if so, where is it? I guess I need to rule out the clutch and brake switches as well. So, where should I start?
Couple of code questions
mdjdc replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is a good suggestion. I will look at the lines this weekend. Thanks
I am working on a friends 99 forester and the car threw the code P0170 for fuel trim. I checked with a subie mechanic and he told me to replace the front O2 sensor. I did that and cleared the codes. Now I am getting a P0130 front O2 sensor and the P 0170 code. What did I do wrong and What should I look at next? Thanks guys.
cut out problem
I'll grab one this evening for you.
a/t flashes at start up
mdjdc replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, the duty C is the same part in all of the 90's trannies.
cut out problem
I may have one on one of my spare intakes. Do you want me to look?
How to pull ignition lock cylinder?
mdjdc replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will drop it in the mail today. Coming to you via priority mail. Mike
So the good news is I had towing
Sounds like your cone washe got all chewed up when it got loose. Replace the cone washer and get the flat washer from a dealer or JY. The flat washer is not actually flat and it works like a lock washer. It actually has printed on it which side goes out and you can see that it had a taper to it. Onece you have those two you can put it all together and be on your way. Do it right the first time and you should be okay. Also, look at the splines on the hub and make sure you have enough left to make that hub reliable. The shaft material is much harder than the hub and I have seen many of the hubs walloed out. If you only have a third or so of the splines left, you will wnat to replace the hub too. It is only going to fail and leave you stranded again. Goof luck
mixed up rocker arms
Not to worry, the lifters are hydraulic so they will make up for any differences in the rockers. I have taken mine out and just put them in a box while rebuilding an ez82 engine and never had a lick of noise when I was done. Not sure about the trick that was possted, but you can just use some grease on the rockers to hold them inplace and when the car is started the grease will dissolve. That is, if you are doing the rebuild with the engine in the car. Personally, I find the whole job much easier wht the engine on a stand and then I can be sure that all surfaces are totaly clean too. Good luck
cut out problem
Keep it simple and don't go looking for lions when there is a cat in the room. It really sounds like a fuel delivery problem and since you had the car siting for a year you probably got gum in the filter. Start there and replace the filter. If that doesn't fix the problem, then do a pressure test on the fuel system to check the quality of the pump, but I am willing to bet that the problem is in the filter. Aslo run some fuel injector cleaner thru the system to make sure the injector is working properly. I like the lucas stuff or seafoam. Another thing that happens is rust in the tank clogging the pickup and you can easily pull the inspection cover and look in the tank for debris. I doubt that is the problem, but it is another check you can do before throwing alot of other stuff into the mix. Good luck
