mdjdc
Everything posted by mdjdc
he whistle is the clue to your problem. I would bet that you have had a CAT meltdown. The cat is now clogged and when you try to acdelerate, there is no where for the exaust to go and it chokes down the engine. Try taking the CATs out and run for a short time with open pipes. You will get a CEL, but if the car runs fine, then you will have the diagnosis. Good Luck.
Question. Does your AT TEMP light come on at start up to let you know it is working? It should illuminate for about 10 seconds or so and then go out. If it does do that and isn't blinking, then your duty C is good and you can save your money. If it soes not come on, then the bulb is bad or someone has taken the bulb out of the dash. You will need to replace the bulb so that you can get the transmission codes and figure out what is bad. The best way to fix the problem is to replace the solenoid, if it is bad, and the grind down the grooves on the drum. Once you do those, the problem should be solved. If you are not sure about the grinding, you can do a search and you will find a thread about the repair.
You need the backing plates and the calipers with brackets. The hose for the caliper to the main brake line at the wheel and of course, you will need the rotor. If you can find that stuff, the swap is very simple. Makes braking much more sure footed. I really like the disc over the drum.
Thanks for the info guys. I got a chance to look at the brakes yesterdaya dn it turned out that the calipers are not sticking. The brackets are a bit rusty and the pads were jamming up against the rotor. That accounts for the burning smell and the heat she was feeling at the wheels. I cleaned off the scale and freed up the pads and all seems to be well again. I will probably get the rebuild kits anyway as they are getting scarce now. Thanks for all of the help, You guys are great. Mike
I converted my daughters car to rear disc brakes. Actually, it was my wifes car years ago and now it is my daughters. Anyway, it has had the calipers on it for several years and now one of them is hanging up. I have been able to source a rebuild kit and I have found some complete XT calipers that are remaned. I am tempeted to get the remaned calipers, but I want to be sure that they will fit on the set up I have on the wagon at home. Are all of the backing plates drilled the same? The caliper I can get are loaded and come with new brackets from rock auto so, I guess, I just need to be sure they will mount on the existing backing plates. Any help you guys can give me will be much appreciated. Thanks Mike
The first three connectors all go together. There is a hose that goes on the fitting coming up out of the engine and a plastic fitting fits into that. Another hose goes back to the intake boot and then one goes up onto the PCV valve. The plastic fitting can break and is kind of pricey. The two hoses are fitted hoses and need to be stock. I may be able to find you a complete setup at a local JY. The last picture is the vacuum boost for the brake booster. There is a hose that comes off the brake booster and it just goes on that fitting. Without that hooked up, your braking will suck. If you have any questions you can call me 804-393-0516
Didyu ever stop for a moment and think that he may have been looking at the car for himself and just wanted to scare you away. The service guys here get a really good deal on the used cars and then they flip thme for a good profit. Son't think for a moment that he was just being honest with you. He may have has ulterior motives in telling you to stay away from that car. As GD said about his car, I too, have a 99 forester and put the additive in my car and have driven on several long trips and have had not a single problem. If I were you, I would go back to the dealer and see if I could get a better deal on the car. If it isn't there any more, check and see if that mechnic bought it. That is, if they will tell you.
Where are you putting those whashers? The only thing that has washers on it is the tensioner pulley assembly. I don't know where you are getting that the others are supposed to have washers on them. I haven't seen a single DOHC motor that has had any washers on any of the idlers. I think that this may actually be your problem. Also, did you check the bolt for the tensioner assembly? There is no reason other than faulty installation or idlers for the belt to be walking. You need to do a bit more inspecting.
Once I get the lock into the door handle ( I only take the lock, not the entire handle out) I put a bit of grease in a socket and put the nut in it and then put it on the stud thu the access hole in the door. It is a pain, but I have been able to do it fairly successfully. I can't remember if you have to raise or lower the window to get good access to the stud though. My biggest hurdle is geting the lock up onto the stud with my big hands inside the door. Almost got stuck once. I usually sue a long needle nose plier to get the lock into place and then push it the rest of the way in thru the acdess hole.
swapping out the entire assembly is not really that big a deal if you have a dremel tool. Use a cut off wheel and make a slot in the bolts and then remove them with a screw driver. Then install the replacement one. Of course, the easiest is if you can get the key to turn, just replace the tumbler. I can probably get you one at my local Jy with a key and I am sure it will be much cheaper than the dealership. Let me know if you want to go that way. I can even pull the door locks if you want them all to match to one key. Mike
NONE of the idler pullies ahould have washers on them. They are installed as they come from the box. The lonly "pulley" with a washer on it is the tensioner and I am willing to bet that the problem is the tensioner being loose and allowing the belt to ride forward. Check it now, before you lose the belt and the valves.
