Nipper
Finally got a chance to pull the instrument cluster out. It was simple enough.
Drop the adjustable steering wheel console all the way. Two upper screws and two kinda hard to get to press down clips on the bezel, three screws to hold the cluster in, and then kinda tough to unplug three connectors (better if you have little hands). I took all three connector connections and cleaned them and then gently folded the cluster connectors out to change the connection points. Plugged it all back in and voila; speedo now works fine. Took maybe twenty minutes.
Thanks, all!
Randall
