Uberoo
    14
Everything posted by Uberoo
  1. 80's accord front springs with the V6 and Air Con fit back there too.
  2. I found a nasty surprise on the passenger side block.it seems that the frontmost/upper bolt was broken off some time ago.Its busted off right at the end of the threads so its broken off about 2- 3" in the block.Any chance of a reverse drill bit being able to pull it out?If I cant get the remainder of the bolt out ,can the other bolts be tightened just a touch more to help seal that corner?
  3. Im taking the heads down to a machine shop tomorrow to check there flatness.I did a preliminary check by setting them down on a granite countertop.one was flat and didn't move at all.the other one wobbled slightly so I will see if its still in spec... one odd thing on this motor is EVERY nut,bolt,etc seems to be on there with a bajillion more ft-lbs than is what is needed.like someone used an impact wrench to tighten everything...
  4. real quick question here.When pulling the heads to change the HG is the loosening procedure the same as the tightening order? IE: 3 1 6 5 2 4 thanks. this is on a 91 EJ22.
  5. I found a 91 automatic awd legacy wagon for $120.it was so cheap because of a blown HG.I bought it as a donor car for an EJ swap,However, a friend offered me way more than I paid for it if I was to fix it and sell it to him.So I get the parts.Then set out to pull the motor last night around 11:45 PM(my neighbors love me).It was all going great until I get to actually pulling the engine.I got the engine about 3" from the transmission then I start hearing a gurgling sound.look at the back of the engine...son of a !!!!!! the torque converter is leaking its contents all over my driveway.So I frantically tried to find a suitable container.found a pop can just in time to catch the last few drops.Finished pulling the engine then I spread cat litter over the ATF.I will shop vac it up later today(after I wake up).Then pressure wash the engine and drive way,(AND my jack,AND the engine bay...YAAAA!!! Automatic transmissions are the devil,why else would there fluid be red? Anyway when it comes time to stuff the engine back in there what is the best way to connect the engine-TC-transmission combo?First time pulling an automatic engine... Also how much ATF does the transmission take?As well as the heat exchanger in the radiator and the TC.does it take regular ATF or is it special?
  6. I just bought a 91 AWD legomatic with 234K and a overheating issue for $120.It overheats after about a mile or so is what the guy I bought it from said,even though it didn't even warm up when I drove it on the trailer.So I will look at it after this rain stops and see what the problem is.anyway I bought it because my EA81 in my wheeler toy ingested some mud destroying the rings or the piston walls...Anyway at some point in the future I plan to T case my subaru and run 31-10.50-15's on it.I was wondering if anyone has ever ran an EJ in a transfer case subi,And what the results were?Im thinking the torque of the ej could help abit when in high range,but then as soon as you put it in low range does it destroy axles?
  7. this is for EA82?if so I usually just bend the top portion of the radiator support out of the way just enough to slide the radiator out.Then bend back the support when your done.EA81 just slides right out the top
  8. what about just removing the radiator? seems like less of hassle.Just catch all the coolant/water.
  9. I took my subaru to a local mud bog.Out of the blue my SPFI conversion started acting up and would randomly stall the engine then it wouldn't fire again for a long time(like 30 minutes).When it ran I was easily outclassing the other 4's.Then it would stall out and I would loose.I will take the harness out and inspect every wire to see if I am intermittently making contact with something.Not to mention pull the dash to eliminate any such problems. As for killing my engine,I had my airfilter mounted back in the spare tire bay so I thought it was reasonably protected.After the first mud race it was so full of mud that it started pulling the mud through the filter and into the engine which is what I think caused the first stall.After that it cranked like I had no compression.so I pulled the intake hose and it was running straight (filtered) mud into the engine.I pulled the plugs and all four had liquid mud on them.So I cleaned them out and re-assembled the engine.I got it to start by pull starting it.It smoked alot of oily smoke out the exhaust whenever it was running.Got it idling and I think I started hearing a faint knocking sound.I tried to drive it around to where I could load it on the trailer and it stalled again.Try as I might I could crank it would fire for about a second then stall again.Still havent been able to get it to fire.it won't even fire when pull starting anymore.Great. I will clean everything up then start taking the engine apart and see if it is salvageable.I think my next engine I might stuff some EA71 pistons in with the SPFI.Then run a snorkel. owning a 4x4 is definably a labor of love.As of right now: my engine is dead,im having wiring issues,and the right front caliper/rotor/pads are messed up because at some time before the mud bog a caliper bolt came undone.
  10. I like it!I like it ALOT! the tractor tires not the funeral bit...
  11. not true.the Body lift on a subaru spaces the engine,tranny,suspension,etc that much much further away from the body so you can fit bigger tires,But won't actually increase your clearance with out the bigger tires.However the suspension lift,forces the the tires away from the body for an increase in ground clearance. For a 5" lift with 1" suspension lift you will need to find some pipe that will fit over the rubber section of your strut top-hat(the rubber section sitting through the body).Use some thick wall pipe 1/4" min if you are going to offroad it.Then some 3/8" or 1/4" plate for for the mounting pads.As for the design itself: piece of pipe big enough to fit over rubber bits on top hat with the ends cut at about 7*,then weld on the mounting pads.To clarify the pipe is vertical with the ends angled in.That should get you in the ballpark,but you may want to leave enough material on the pads to make some adjustments to bolt holes if camber isn't quite perfect. BTW to all those just screaming search: that actually makes it harder to find some thing because then people have to wade through tons of posts just saying to search for it instead of a couple explaining what it is...
  12. I would say 4" to fit those tires,but then I am not sure how much outback struts lift the car.IIRC they lift the car about 2" so then a 2" strut bottom lift?
  13. all else fails unbolt the control arm from the body,disconnect the swaybar(or toss it).everything else can stay connected then it will be easy to get the strut blocks in...
  14. Uberoo
    Sut
    Yea Im planning on putting a window in there.Although there isn't much hurry.Just as long as I put a window in before it starts getting cold... haha
  15. 1993 Subaru Legacy FWD sedan a couple weeks back the right front wheel bearing on my car died.It was making noise and if I jacked the car up there was alot of play.All the other wheels were fine which I thought was odd but I told that is reasonably normal.So I tore down the car and found out that the bearing had been wearing the hub away so the hub was shot.I went down the junkyard and the only thing they had was a hub of a 97 lego with abs,but it would fit my car and came from a donor with only 120K miles compared to my cars 170XXX.It had no play.It was perfect when I installed it but lol and behold not a week later it started making noise again.I had to drive on a 4 hour trip the next day(8 hour round trip).It made it back without any problems other than the wheel bearing/hub getting progressively louder with each mile.Now it has a very loud constant drowning sound so by now I know the hub is shot.So I am going to find a good hub then press in new wheel bearings.However,before I do that I would like to know what would cause a bearing to just fail like that in a short amount of time?I mean the new bearing was perfect then failed less than a week later in city driving.
  16. heres my bumper before I added D ring shackles to the front of it with 3/4" blocks. Bumper is a piece of L channel about 3/16 thick.It is held to the car with some C channel thick wall 2" c Channel.Bumper mounts go into the car 22" with 3 7/16 bolts on each side holding it on. It held up until I got my car stuck in some cement like mud up to bumper.the recovery effort bent the bumper itself and bent a channel support.not to mention, it pulled the bumper a little less than 1/2 an inch further forward in the body(tore the sheetmetal a little)
  17. Uberoo
    Sut
    Id like to put in a tailgate but I am not sure how to set it up to function right.Right now the lower edge of that panel is sitting on the bumper(its how it sat before I played with it) so it would need a fair bit of work to get right but its definably do-able.
  18. Uberoo
    Sut
    So I decided to convert my EA81 wagon wheeler toy into an SUT.Or 4 door trucklet,what ever you wanna call it,etc...Right now its not done.I still have to weld in some cover pieces in the area's where there are gapping holes in the sheet metal like where the D pillar was.Then im going to weld in some pieces to where the window should be to give a bit more of a finished look.Some people will hate it some will like it.I know removing weight from back there helps abit offroad.Anyway,here are some pics of its current state.Eventually I will put in an intergrated roll bar at the back of the "cab" as well as some sheet metal for some lexan to sit.
  19. ENGINE HOIST: Handy tool for testing the the tensile strength of ground straps and clutch lines which you forgot to disconnect. As for the color is that grave digger green? or goosebumps green?
  20. would dowsing it with water make it brittle? Is there a stock spring for a subi that is stiffer than a 2wd EA82 wagon front spring but softer than a 4wd EA81 wagon front spring?
  21. is the sway bar still connected?
  22. On my EA81 wheeler toy when I put EA82 suspension under the front of it I seemed to have lost a couple inches in ride height because I am running EA82 FWD springs to help get the best travel out of the front.A little bit helps out a lot.I am wondering if it is a good idea to move the spring perches up on the strut to help with the height drop. Obviously I can't just lay a BIG bead all around it in one go.I will make deep tack welds and work my way around while letting it cool off so I shouldn't have a problem.I know that moving the springs up will increase the preload.So at that point I wonder if it would be just better to run 4wd springs and get my height back at the expense of some some travel.Is there a way to calculate how much moving the perches will effect the preload?
  23. still looks good though.almost like someone could have actually built it.
