bigtexan99
Location
San Antonio
Vehicles
I Love My Subaru
bigtexan99's Achievements
Member (2/11)
10
I've had the AT light flashing for a long time in my 99 Impreza Outback Sport. After going through the code readout, the blinking lights said I had a "defective temp sensor". So, I ordered a new temp sensor, dropped the transmission pan and replaced it. It's pretty easy, just plug and play into its little harness. After about a week, the AT light started flashing again, with no apparent reason. Sometimes it starts flashing after 3 minutes, a couple of months ago I drove from Texas to Florida and back and it never blinked once. It blinked yesterday. I put the AT light in diagnostic code output again, and now its spitting out code " 1long, 1long, 7 short" which means code 27. What is code 27 for again?
Just a fyi, my master cyclinder went out on the OBW and replacements are far and few between. So, if you are planning on replacing yours anytime soon, allow some time to get the part. Even the dealer said it would take a week or more to receive it. Ended up buying on the intenet from somebody in Delaware.
It's not actually a stereo. It's a in dash VGA touch screen that I want to mount. Here's a link to one on ebay: Search on item number 300002248561 I'm going to mount a port replicator for my laptop in the car, have not decided where yet. Then, I will have a touch screen available to interface to the laptop. this will allow me to use the screen as a GPS tracker, as well as stop next to any Starbucks to check my email. Can also be used as a DVD monitor.
The vent tube is on top of the rear differntial, between the differential and the underside of the car. That is a good point about the bad seal, but my mechanical advisor felt that it was leaking because there was excess fluid (water) in the differential that was forcing it out the seal. Like I mentioned, opening the top plug, which is how you check the level resulted in about 12 oz being spewed out. On a 'normal' differential, you should be able to remove the plug and the fluid is right at that level. So the theory is that the leak was caused by excess pressure. I'm driving to Florida tomorrow to watch the shuttle launch, so I will keep an eye on it to see if it leaks, or if the leak has stopped now that the pressure is reduced.
Today I was under my 99 OBW and noticed a little fluid leaking at the rear differential. Seemed to be coming out of the spline seal. Decided to pull the fill plug and check the level of the rear differential oil. Imaginge my suprise when about 12 oz of milky white gear oil came pumping out!! Went ahead and drained and replaced the diff oil. Turns out, the last time I put my boat in the lake I must have backed up to far, allowing the differential to be submerged and water to enter through the vent tube. So if you regulary back your ride into the lake.... you may want to check your differential fluid. Steve
