gritle
Everything posted by gritle
Join Date: Dec 2005 City: Minneapolis State: Minnesota Age: 29 Posts: 198 iTrader: (0) Vehicles: 96' Legacy Brighton Re: trying to explain the change in my car Before you shell out $500 for clutch, make sure there's no easy fix. Check fluid in clutch cylinder, check that there is some freeplay of clutch pedal.>>what do you mean by free play?
120,197. nxt oil change is 'due' 120,910 I think I had the timing belt changed just over 1.5 years ago. It is a manual; and yes seems to go into neutral between gaining enough speed for the next gear. Doesn't seem to be a clutch problem to me. Not sure about checking fluid levels at this point... where would I check the tranny fluid? I'm not too engine savvy
I'm going to try to explain this the best I can. any hints suggestions, thoughts are greatly appreciated. I drive a 98 legacy wagon. i think it is a six cylinder but am not sure. awhile ago the check engine light came on. No real difference in the driving of the car. i did notice a bit of an oil burning smell after driving long distances. I determined there was s mall oil leak which dripped on to the exhaust manifold. I have not had this repaired. recently the weather dropped quite a bit and I've noticed a change in the acceleration of my car. I can go from 2nd to 3rd and have the tach jump up to 4 or 5 K. So basically while shifting from one gear to the next there is a lag in the acceleration to get to a comfortable speed for whichever gear I'm moving into. I do plan to have this checked out when I have an opportunity but I have little funds to do this in a timely manner. Could it be that a lack of pressure due to an oil leak would cause this change? The pistons seem to clap a bit but maybe I shuld just give it more oil until i can have it checked. last oil change I had seemed to make a big difference. If anyone has any specific suggestions or can give me some sort of diagnostic impression from this I would be very happy. thank you
is there some kind of a way to recharge th ac myself. It might have a small leak or a pblm with the relay but i have had it working before i imagine I could get some freon to put in. Most shops won't do it without charging me 100+ dollars.? also someone gave me great tips on fixing my cruise control. it has been fine thank you. USMB
I hope someone can offer sound advice on this one. My driver's side headlight has gond dim. I purchaed a new bulb for it but still it is dim. i don't want to have to pay ridiculous shop labor for something that may be a qucik fix. on another note. does anyone have a hnit on aiming the headlights. i bought my subaru '98 legacy wagon with no owners manul.? thanks for any help, gritle
