tidd1340
Everything posted by tidd1340
Well,it was the wires.The previous owner fixed the defrost wires but just left the wiper wires broken.All fixed now.Had an issue though because the wiper fluid hose was also cut and worked its way down the rear pillar.I tried for 90 minutes to run a wire down through to tape to the hose and pull back up,with no success...any ideas on a better way?
My 95 legacy 2.2 has a random no start issue...no real pattern..will start fine,the when you go to start it again,no go...turns over fine.Figuring fuel or ignition problem.Car runs fine otherwise.This was a problem from the previous owner,so i don't have allot of history..any thoughts on where to start? Also,i have the hill holder unhooked.Is there any adjustments that need to be made so the brakes dont drag? In other words does the HH need to be hooked up? thanks.
Just about to remove the motor from my 95 Legacy 2.2/manual trans. Should I remove motor mounts from the cross-member or remove the bolt from the bottom of the motor? The lower motor to tranny bolts have nuts on them..i removed the nuts..will these bolts slide through when I take some weight of the engine?
