goatcheez
About goatcheez
- Birthday 01/23/1967
Location
Central Illinois
Vehicles
Subaru Loyale Wagon AWD
goatcheez's Achievements
Advanced Member (3/11)
10
Time To Say Good Buy To My Loyale...
goatcheez replied to goatcheez's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's the link to my craigslist ad.... http://springfieldil.craigslist.org/cto/1635065112.html goatcheez -
Ad is now up in classified section with pics. Looking to get $800 obo. goatcheez -
The time has come to say goodbye to my 1992 Loyale Wagon, 4WD, 5-speed. Been a good car, still is a good car but I decided to move on. Placing info on in the classified section shortly. I'm in central Illinois. PM me in you are interested. Thanks! goatcheez
1992 Loyale Wagon Died On Freeway
All fixed!! Thanks for all of your help! Even though I had put a new t-belt kit on her back in August, I decided to replace BOTH belts. Heck, their cheap enough. I checked the tensioners and pulleys everything seemed to be turning freely. So, as of right now, my diagnosis is just a bad belt. Went with a little more expensive brand this time too. So far so good. goatcheez -
Thanks! Still gonna have to do some research on the cam and flywheel markings. No oil leak. Gonna check pulley(s) tomorrow. So far I'm glad it's something simple (relatively speaking) and not an electrical issue I have to try to track down. I'll keep you posted.... goatcheez -
Found it!! It WAS the timing belt, drivers side. I didn't see it until I got underneath the car. I just put new belts (whole kit with tensioners) on back in August. Looks like I got a bad belt out of the box. The t-belt covers are off, left 'em off after I did these the last time. Getting to it is easy. Okay, so here's my question. Finding top dead center. I had help from a friend when I did these before. Gonna be doing this one on my own. So finding TDC and adjusting the timing is beyond my knowledge. Any advice or tips are always appreciated. goatcheez -
Thanks for the reply. Yeah, I've gotta do some more homework. It's colder than a buh-jeeb-eez here in central IL and I probably won't get to it til this weekend when I can warm up the garage. Just thought maybe there was a common problem that might be a good place to start. Still open to ideas. I'll keep you posted. Thanks again! goatcheez -
Hi All! My 1992 Subaru Loyale Wagon died on me today while I was getting on the freeway. No warning it was just like I had turned the ignition off. To help narrow down the cause, here's what's been done to it over the last 6 months. New timing belts complete - August (covers still off - checked em look good) New fuel pump - October New Brakes/rotors - rear shoes - July It was running great up until this point. Can hear fuel pump prime when attempting to start. Doesn't even sputter, just cranks and cranks. Could this be an electrical issue? If so where do I start to diagnose? As good as this car was running before the failure, logic tells me it must be something simple. (I hope) Any tips or advice is greatly appreciated. goatcheez
I had posted this about a week ago and looks like the server switch toasted it. Here it is again... My 1992 Loyale wagon is spraying oil on the underside of the hood. It's near the front, passenger side of the hood and settling some on the aircleaner cover and fan shroud. I can't, for the life, of me figure out where its coming from. A few of you posted some theories and I checked on a couple of them. First..."O" ring seal on dipstick. It was infact shot. I replaced it. Still sprying oil. Second...Cam seal or Oil pump seal. Well, could be, but I looked and looked and looked again and I can't see where it's leaking from. That's about as far as I got so far. Again, it's not "using" any more oil than normal for this motor, mileage, and age. Oil presure reads normal. Car is running fine. Does not seem to be spraying oil on trips around town (3 or 4 miles) just after my 40 mile commute. It seems to be sprying off the pullies or belts but belts are clean. Very little residue on oil filter too. I'm stumped. PCV valve?? I trying to nail this down before the snow flies here in Wisconsin. Help!! goatcheez
Fuse For Auto Seatbelts??
Thanks for your help guys!! I will look at the fuses this weekend. It's a "tropical" 3 degrees here in Wisconsin today. Supposed to warm up this weekend. I also am concerned about the "relay box". If its in the wheel well as mentioned in an earlier post, that could be my problem. I noticed after I bought the car that there is a leak (water) somewhere in the rear of the car that causes the passenger side rear footwell to "puddle-up" a bit. How hard is it to pull the rear interior trim pieces off to take a look?? Do I have to pull the back seat out?? I'm thinking of it's not a fuse it's gotta be a salt water gunked-up realy box. Again, I'm working around the no autobelts for now but would like to fix it (and the leak) when we get some warmer weather. Thanks again!! Sean -
Anybody?? Thoughts?? goatcheez -
Okay, I looked in the owners manual and there is no mention of a fuse for to Auto Seat Belts. Neither side is working (they did up until today) so I figured it must be a fuse. It's a 1992 Loyale Wagon. Any help would be appreciated. I know, I hate 'em too, but with the seat belt law here in Wisconsin they've save my butt a few times. Not to mention in a crash situatuation. Thanks guys!! goatcheez
Are these possible to get (lights)
goatcheez replied to tizzle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am totally in for a set of these!! Keep us posted!! goatcheez -
I don't miss it at all!! Runs Great!! Got the tailgate fixed, put new tires on her, fixed the heat, scrubbed the interior, put rear wiper blade on, got the AC working without the homemade switch, adjusted the driver's door, got a lead on a new "stock" rear bumper, ordered new bushings for the shifter, and had exhaust fixed with new cat. Nope I don't miss her at all. Milemaker, if you ever want to take her for a spin, you know where to find me. goatcheez
Hi Guys! I just posted this in the "Subaru Parts Wanted" forum, but I thought I'd put it here as well.
