bigjim5551212
Everything posted by bigjim5551212
webbr carb on 1987 gl wagon
bigjim5551212 replied to glh1975's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you need any parts, give me a call 1-800-665-5031 Jim -
We supply new and used webers. I would look for a used Weber first. You should see my "used Weber guide" We have all the repair parts and jets and anything you need. We could supply a complete new kit as well. call me a 1-800-665-5031 if you like Jim
How do distributor caps work anyway?
bigjim5551212 replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there are 2 lots of sparks in the ignition system, 3 if you count bad points. points, distributor cap, spark plugs. -
Quick Brake Question
bigjim5551212 replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the cheapest factory subaru accessories place I found was Don Jacobs Subaru, -
Rear Wheel Drive Loyale!
bigjim5551212 replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The First Generation RX7 would be good. Its a coil spring rear end. They are 3 rear ends though. 1-Drum Brake, open diff 4 x 110 pattern 2-Disc Brake, Limited Slip 4 x 110 pattern 3-GSL-SE Rear End, 4 x 4.5 bolt pattern, vented disc brake rotors there are few ratios you can get from Mazda Motorsports as well.- 27 replies
there are a few stellars left here, them and the Pony's have mostly disolved- 27 replies
Thats awesome
well, i dont know a lot about factory carburetors, but this is what I think. the idle cut off unit is shot
If you are looking for a rear drive straight axle conversion, here are are few ideas Corolla GTS 84-87 has disc brakes, 4 on 4.5 bolt pattern. Coils Datsun HL510, PL510 Wagon, 710 Leaf Springs Chevette Coils? Mustang 74 to current Maverick 70's Dodge Colt in Canada Hyundai Pony- 27 replies
if you can get sealed beam buckets, you can then put in H4 headlights. Are you familiar with H4 Headlights? They are the best.
you can put H4 headlights as a conversion. They are superior to anything and way better to keep your singles than a 4 headlight kit. UNLESS You have the 9004 do6 5hit headlights and you are going to put a 4 headlight kit in.
The idle speed should be smooth and not hunting. The idle speed screw should be able to be turned out to reduce the engine speed, all the way to stalling. The same with the idle mixture screw, it should be able to be turned all the way in to stall the motor. If the idle speed screw gets turned all the way out and the engine still runs, then there is a problem with the cable maybe. Something is not letting the throttle plate close all the way.
I think you have a vacuum leak still. Get a can of WD40 and spray it around all the gasket areas. Check as well, your power brakes. The diaphragm could be leaking. Check as well, the throttle shaft of the Weber. They do wear. We have a throttle shaft bearing kit that takes care of those issues. The secondary should not be adjusted. The secondary throttle plate should be closed and the screw should be peined.
if the pump in the carb is shot, then it will cause a hard start. The fuel needs to be injected to get the engine to run fast enough to suck the fuel from the venturi in the carb. Time for a Weber perhaps? We can help
We supply PIAA, Eurolite bulbs, headlights. We are also handling Bosch and Optix HID Kits and replacement parts. Here are a couple deals YL-Yellow H1, H3, H4, 893, 9005, 9006 $21 pair including tax. 9007, H7 $23 pr including tax H10, H11, H8 $27 pr including tax H13 $45 pair including tax.[/b] XB-SAE marked White H1, H3, H4, 9004, 9006, 9005, 9007, H7 $20 pair including tax except 9006XS, H9, H11 $25 pair including tax SB-Fusion HID color H1, H3, H4, 9004, 9006, 9005, 9007, H7, H1 (H1LXC) $20 pair including tax except 9006XS, H9, H11 $25 pair including tax We are supplying the Bosch HID kits for $225 shipped for single beam and H4, 9004, 9007 and H13 kits are $450 shipped.. Check our PIAA lights website, www.piaalights.com this site has a lot of great pricing and you can order on line. Give us a call at 1-800-665-5031
We are supplying the Weber Complete Kits from Redline. Call us for a fair price shipped to your location. We also have all the jets, repair kits, air filters, our special throttle shaft saver kit and adapter plates. DGV and DGAV repair kits $30 Power Valve Diaphragms $20 Throttle Shaft Bearing Kits $20 Air Filter Kit, 1 5/8" $25 Jets, mains, airs, idles $5.50 each Shipping is about $15 for a bulky package, parts in a padded envelope are $9 Call us today 1-800-665-5031 or email me at jim@overseas-auto.com see our Websites www.overseas-auto.com www.piaalights.com and soon, www.weberjets.com
Where's the carb number?
bigjim5551212 replied to dem577's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a pair of glasses to look at small numbers now -
much heat from a torch will sometimes help. maybe if you can dismantle the whole thing, suspension and the shaft from the diff, you can take it out, then you dont have to worry about the rubber parts soaking up the impacts
We sell a fair amount of HID. the best color is 6000k. Why, because its white, and not blue. The 4300 is ok, but its yellow. Now, what I would do is to scrap the 9004 housings and put in 4 rectangular headlights and use the H4 conversion type headlights. The light will be more superior.
the egr valve is generally vacuum controlled. You could use a vacuum signal from the carb. There are 3 vacuum connections on most DGAV weber carbs. 1 is beside the vacuum advance hole and the other is at the venturi. if you use egr then there will be less pinging. It does take a bit of power away. You could block it off with making plates from steel plate.
The performance difference is not that much. Here are a couple comments. 1) the throttle shaft on the DGAV DGV series can be repaired with a bearing kit, so there is no slop, the DFAV series can not 2)The air horn is the major thing thats larger on the DGV series. The air horn on the DFAV series is smaller. The venturies are the same, 26 and 27 mm, and the opening on the bottom of the carb is 32 and 36 3) The linkage is reversed between the 2 carbs
1983 brat carb problems.....
bigjim5551212 replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
make sure the pump jet is squirting fuel into the barrel of the carburetor. Jim
