Location
North Wildwood
Vehicles
'87 GL Wagon
IrocRacer's Achievements
Member (2/11)
10
haven't tried that yet b/c i don't have another car to do it
I had it working for like 5 minutes steady sounded great and then like the light would dimm out then come back on and dimm out and over and over....Yes the remote is hooked up
Ok...this i don't get...i got all of my car audio equipment together and tryed to hook it up in my 88gl wagon the new radio works but thats not the problem...the problem is i hooked up my amp to a bandpass box and the amp keeps on coming on and back off..now here's the funny part....i changed where i was grounding it from whitch was the driver side metal piece directy to the battery and got it working for a few minutes then it was turning of and coming back off again......any ideas?
Ok...just realized that i don't have an o2 sensor...?Would this this make my car not idle and how do you hook it up?Oh... I got an 87 GL Wagon
Hey i'm working on finding out what these are...if i didn't know any better i think that these are old school MG Rims i belive
Thermo Vacuum Valve on an 87
IrocRacer replied to IrocRacer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
kool thanks -
what do barbs look like? -
Ok just to ask....what does this thing do b/c i was going to check it but i snaped the pieces off....is this important to keep the car idling?Any help would be great.
Do You have a diagram Of this and if you do can you copy it for me?That would be awesome
Extra gauges with the dig. dash? optional???
IrocRacer replied to subeman90's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm New to Soobs But i think this might help.http://www.cars101.com/oldsubaru.html -
I got an 87 gl wagon 4wd ea82 And this is geting insane.First to start,i replace the carb b/c it needed it b/c the choke locked up and i wasn't messing with that.I replaced the fuel filter,i replaced vacuum line but not alot,I replaced the Egr Valve gasket b/c the Egr Light was on which i found out how to turn it off.I replaced two Parts of the exaust,The front part of it and i replaced the muffler b/c the top of it was split in two places.So anyway back to the problem,I pump the gas 5 times and start the car,it starts but i have to give it some gas to get it to stay above 2000 rpms then some time i can get the car to saty in idle but then if i try to put it in reverse or drive it will stall or idle rough....can someone help me with this b/c my patience is wearing thin and i need a car period...If i cant get this running then it's getting sold but i really don't want to get rid of it.Any help would be great.Thanks:headbang:Oh and if the problem doesn't get fixed then if any one wants to buy it i got pics of it.
Yeah..i just done it recently and it's easy...just make sure thats theres not alot of rust and remove the bolts that connect to the converter...you will need two tools,1 A rachet with a socket and a wrench and after you do that clean the area with a wire brush and if need use a razor blade to get the rest and insert donut gasket put bolts back on and you set.
