On my 04 outback i fried it :-)
We ran a baby bottle warmer of an inverter on it, that thing was probably lke 500W, so now that i think about it, that would be 500/12 =~ 40 Amps !
Anyhow, the crazy thing, is the inverter fuse did not blow, no subaru fuses blew either (wether under steering column or motor comp) which does not seem right btw.
Yet the Plug does not work anymore (though the "backlight" on it still works).
By the way, the mirror lights and the "trunk" outlet which are supposed to be on the same circuit do work.
Anyhow obviously, there is either an hidden fuse behind the plug(did not find one), or a "wire" itself burned.
I saw on that post a comment about "bridge wire" would that be the likely culprit ?
Also any tip on accesing/removing the front cigarett ligthter.
So far i removed the small storage/trim in front of the shifter and also the ashtray, but can't figure out how to remove the rest of the central console (cd storage), or at least the lighter itself,
I need it just to run the radar detector, won't pull 500W of it again :-)
Thanks for any tip about what could be wrong, and how to gain better access.
