blitz last won the day on August 4 2006
blitz had the most liked content!
Contact Methods
Website URL
http://
Location
Warren, Michigan
blitz's Achievements
1000+ Super USER! (9/11)
0
I order parts all the time for the electronic repairs I do, and for the last year and a half I've been running into backorders, backorders and BACKORDERS. There's something odd going on in the economy that I can't quite put my finger on ...like a game of hot-potato or something - whoever gets caught with inventory when "the deal" goes down ...loses. This is something unlike anything I've ever encountered before. My '00 OBS sat on jackstands for three weeks first waiting for a backordered strut, then for backordered strut bolts.
Heat is a major enemy of neoprene seals and fries 'em into tasty bacon crisps. Synth fluid might be able to hold-up under high temps, but don't be fooled into thinking that the seals will come out unscathed. Keeping the tranny fluid temp under control is key to extending the life of the trans. It's no small deal.
Fram parts?
blitz replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The ADBV isn't a brand-specific thing. Some part numbers specify an ADBV, others don't ...including Fram. The Purolator L14460 that I use doesn't have one ...the Subaru OEM fiter (made by Purolator) DOES have one. The sump is the lowest point in the system and the oil pump moves the oil uphill from there. After shutoff, gravity does siphon the oil backwards through the stationary oil pump clearances, back through the filter media, back into the sump. How long does that take? I dunno. The filter orientation doesn't affect it. Whether the ADBV is critical is debatable, but it sure can't hurt. -Learsi -
It's three-wire circuit; hot, signal, & ground. There's no way to do it AFAIK other than to drive around with a meter connected in at various places in the sensor harness (at connectors ideally) to spot intermittant readings in the hot, the signal, or the ground. Usually it's one of the connectors that's acting up, but also a wire could be pinched or broken. Most mechanics don't like to be bothered with such time-consuming diagnosis ...it doesn't pay money. They swap parts instead. **** ******!
Here's the text of the conditioner propaganda. **** ******! --------------------------------------------------------- WWP-99 Service Campaign - Cooling System Conditioner Subaru has determined that certain 1999 through 2002 model year 2.5L equipped Subaru vehicles may experience an external coolant leak from the cylinder head gaskets. This is the result of normal relative thermal expansion and contraction variations of engine parts. As a precautionary measure, SOA is recommending that a special conditioner be added to the engine cooling system to prevent leaks from occurring or to correct existing leaks. Only early Phase II 2.5 liter engines are affected by this campaign. Phase I 2.5 liter engines (some 1999 model year and prior years) are not affected. Countermeasures applied to the manufacturing process for those 2002 and later VINS not affected by this campaign have eliminated the need for this campaign to be performed on those vehicles. In the future, it will be necessary to add Genuine Subaru Cooling System Conditioner to the SUBARU vehicle cooling system whenever the engine coolant is replaced. The updated recommended service procedure as well as intervals for coolant replacement will be added to all applicable service manuals. As a reminder, we will include an update page in the owner notification letters that should be added to the Owner’s Manual and Warranty and Maintenance Booklet. We ask you to keep in mind that replacement of fluids (including Subaru Cooling System Conditioner) during inspection and maintenance services are not covered under warranty. If the vehicle owner has this Service Program repair performed promptly, Subaru will extend coverage under the Subaru Limited Warranty on the vehicle for cylinder head gasket external coolant leaks to a period of 8 years or 100,000 miles, whichever occurs first. Warranty coverage begins on the date the vehicle was delivered to the first retail purchaser. If the vehicle was used as a demonstrator or company vehicle before being sold at retail, warranty coverage begins on the date the vehicle was first placed in such service. As a further condition for this extended warranty coverage to apply, the vehicle owner must have Genuine Subaru Cooling System Conditioner added to the vehicle at any subsequent cooling system services at the interval specified in the Warranty and Maintenance Booklet under the heading “Schedule of Inspection and Maintenance Services”. Dealers will automatically be sent an initial quantity of Genuine Subaru Cooling System Conditioner. Dealer bulletins and affected VIN lists will be mailed to dealers in early February 2004. Owner notification letters are scheduled for mailing in stages.
