testy
Everything posted by testy
this is a cool idea.
wheres the offroad modification sticky gone?
testy replied to Scott in Bellingham's topic in Off Road
How is the carbed ej22 working? -
EA82 4x4 stuff swap into EA82 FWD?
testy replied to testy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Great. Ill just use the 4x4 car as a reference. Thanks guys. -
I understand the mustache bar. I dont know what a carrier bearing is. -
Just made a deal for a rust free 91 FWD EA82 Wagon. 5spd, FWD, Loyale. $200. Can I swap my 87 EA82 D/R 5spd 4x4 stuff into it? I'm going to install the rear portion of my lift at the same time. What is everything I need to complete the swap. The FWD car needs a clutch, the clutch from the 4x4 car is fine. So as far as I know I need to use the 4x4 flywheel? I dunno, what is everything I need. Thanks.
Go to your autoparts store. Buy the Accell superstock plug wire generic set of 10, they are 8mm and it was like $50 canadian. It came with good sizes for the boxxer engine. Get the Accell superstock coil. And then get new plugs. As for a clutch, ebay?
Bump for good thread with great info.
WRX = TURBO. Definatly go with a 99 Forester Motor. SOHC, very reliable, 160 underrated horsepower. Very easy to coax more hammies out of that. Also, early WRX are all 2.0L I wouldnt hesitate to go with a turbo for offroad if I could afford it. I would pay special attention to securing ALL the exhaust as high and as tight as possible on the car. I would also run a significantly smaller turbo.
Do not put the chains on the rear tires. You will just understeer and its quite dangerous.
Umm. With that much horsepower why dont you go with a 31" tire?
(4.11 or 4.44 ring/pinion) into D/R EA82?
Interesting. I guess for now I'm stuck with 3.90. At least I know I can put an LSD in the front and weld the rear. -
? on using NA block for turbo application
testy replied to wes200x's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Alluminum shavings will do less to a motor than most think. -
Yes. What trannies did you have apart. I want to swap the ring ang pinion gear in as a set. Do you think the ring/pinion gear (essentially the whole diffrential) from a 90-94 legacy 5m/t will go into the EA82 case? -
I know it has been discussed. But the threads its in are so full of fluff I cant reconize the answer. The auto trannies are a totally different animal than the m/t. I want the gear for offroading. I figure even a 4.11 will make a huge difference once Im in 4Lo. Im aware the carriers work, clutch LSD for me plz. But was hoping I could get a lower gear as well. -
testy posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Will a 4.11 or 4.44 ring and pinion gear go into the the 5spd N/A EA82 Dual Range tranny? Im like 100% sure that a 4.44 wont work. But dont some 5spd legacy's use the same front diff design and have a 4.11 gear? -
Silver Powder Coat would look bomber on those man.
Scott. Nice work man. I just bought an ej22 from my mechanic. And my lift should be here in a week or so. Think you could pm me a christmas list or better yet post it here for everyone. Need ALL the parts to make this happen. Also, could I send the intake manifold down to get setup for a weber 32/36? And send a disty down to be ground.
Nice. I asked him for red blocks too haha. Almost ready to ship that sucker?
