Everything posted by nkx
Regular or Premium?
87 will get you by in a pinch if you baby a turbo car. keep your foot in it, and expect knock and maybe some broken rods or pistons.
Worst color?
i am never buying another white car again! hard as hell to keep clean. it looks good for 24 hours after you wash it, and then its filthy again.
1st post: 86 4WD blown engine- $100!
spfi is single port (TB injection, iirc), mpfi is multiport.
carbon fiber hood RX
i think its just painted black, not cf.
ea82 gl10 seat gadgetry?
heh... but seriously though, my gl-10 had the lumbar support. you had 2 positions. painful, and more painful. its like a rod that goes lengthwise that jams into your back when you move the adjustment.
water injection system
water injection is a poor substitute for proper intercooling.
Carlisle May 19-21
matt, i registered the buggy and the wrx. scott, you have mail. if anyone needs directions, lodging info, or anything else of that sort, get in touch with me. im the local guy and can dig up whatever you need. -john
updated headlights for EAxx cars?
im working on fitting some hella units as an upgrade. my headlights suck, and i dont want to replace them with another sucking OEM assembly.
I thought it was a joke this whole time.
someone posted a pic of an RS a few weeks ago. it was a 3 dr coupe. ah, found it. maybe RS was a rarely used package designation until the impreza showed up.
Carlisle May 19-21
aww shucks!
Carlisle May 19-21
living in york, you wouldnt have to camp if you didnt want to. carlisle to york is ~45 mins depending on traffic.
Swaping turbo from 2.2t into 1.8t
rumor has it you can bolt on a downpipe for a wrx.
Subaru's In PA
hmm, i live like 45 mins away from you...
Braided stainless brake lines
i should call on monday. my pedal is plenty firm, i just need protection from pads catching on fire.
Subaru's In PA
check out the thread for the meet in carlisle in may.
Outback hotness....
nkx replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes. he does. search on old school. every other thread on suspension or eeking out horsepower has at least 1 post from will in it. do a bit of research on his background before making assumptions.
t3h hawt interior pics thread
his deck has a tilt feature. lots of your midrange to high end headunits do that now so you can adjust the viewing angle.
custom fenders....
carbon fiber is like fiber glass, but instead of just curing out in the open, it needs to be cured under pressure while heat is applied. raw cf is expensive too. you could probably lay up some pretty healthy fiberglass fenders if you go over it with several layers. plus you can repair it if the damage it suffers isnt too severe. i dont know if the same can be said for cf. i think takes a bit more of a beating than fiberglass, but will pretty much shatter when its pushed over its limits (ever watch an f1 car crash?)
Steering Quickner..RALLY CAR BUILDERS! Anyone ever Installed one!?
you could always try a smaller steering wheel. maybe if youre lucky the manual steering racks are faster. i dont know, im pretty keen on keeping my power steering.
ea82 speed question
isnt the tranny going to bind in 4wd while hes turning?
Fleet Meet!! *pics*
my 89 gl-10 turbo wagon 5 speed ft4wd and my 04 impreza wrx 5 speed
Outback hotness....
nkx replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlooks like you sit WAY lower than my wrx. and its lowered. how do you not scrape?
Suspension Tech/Spring Upgrade
my 89 gl-10 turbowagon didnt come with a rear sway bar. calebz's wagon is the only wagon i know of with a rsb.
heres 2 pics after i got my corbeau seats in. since ive finished gutting the car, minus the dash and a little bit of the console. added sliders from non-height adjust seats from a gl to get the seats down a little bit. still need to lower them another inch or two.
Tierod help...please! fixed!!
actually this is incorrect. bending will actually strengthen metal to a point. ever notice if you bend a spoon its always harder to bend it back? now that being said, the metal will also become more brittle, ie: it will tend to shear instead of deform. bending the tie rod back could be used as a quick fix, but i personally would get it replaced as soon as feasibly possible.
