Everything posted by nkx
very cool... how loud is it? sound police go after you often?
according to the SPT brochure, sti brand radiator caps hold 18.9 lbs. fits impreza and forester.
Benefits of putting Impreza/Legacy/etc. exhaust into XT/XT6?
nkx replied to Phaedras's topic in Subaru Retrofitting
if you get an xt with an ea82t, you can bolt a vf11 off of an early legacy turbo, and from there you can bolt on a wrx downpipe. im not sure of all the exact details, because i havent done it yet... will, care to chime in? -
installed a mbc and still only 6 psi
nkx replied to 87hatchbackturbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what kind is it? did you make sure all your hoses are clamped tight? did you try to adjust the controller? -
lol, kinda looks like my computer room right now, half computer junk, half car junk
ive got a huge list too, but no specific timeline... -paint rear where rust was repaired -install sti hoodscoop -install wrx intercooler & plumbing -install a new muffler -upgrade suspension -steering rack bushing mod -replace sunroof with steel -replace gl-10 drivers seat bracket with non-height adjust bracket -paint/powdercoat 15" pugs -redo intake tract stuff on the backburner: -rally mudflaps -repaint entire car -redo entire exhaust, turbo back 2.5" -rollbar/cage
the uppipe is the exhaust manifold/header/crossover pipe. this is connected to the turbo. then you have the downpipe which flows exhaust to the cats, then to the muffler.
Help adjusting Turbo XS boost controller
nkx replied to XSNRG's topic in Old Gen.: 80's GL/DL/XT/Loyales...
do all ea82t's have a stock boost controller mounted on the fender? i have a turbo off another ea82t and it just had a line from the compressor that went to the wastegate. -
theres a stock boost controller? i have the plain turboxs boost controller. i hooked mine into the line that goes between the wastegate and some pressure line that came from something mounted on the passenger side fender. works like a charm! -
ah ha! i see youre the only other person who knows how to correctly install a turbocharger. slap it on!
okay, who has modified their EA82T fuel system?
nkx replied to Snowman's topic in Subaru Retrofitting
ah, now it works... i like that setup. thats a RRFPR, right? whats the black hose coming from the front of it? -
ah, linky no worky... -
how does the car ride? my friend put some el cheapo coilovers on his cavalier, and he hates the ride, its too bouncy.
Book Value of: EA82T 5SPD FullTime 4WD Wagon
nkx replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it might be worth it if youre considering buying another subaru and upgrading it. gl-10s already have a lot of goodies from the factory, so you might be saving yourself time and effort. what year is it? check the fenderwells and underbody and exhaust system for rust. depending on the condition, you might justify talking the seller down. -
RX Turbo Dyno Results - Playing with Fuel Pressure
nkx replied to Myxalplyx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think hes trying to say your injectors are still opening the same distance, and staying open for as long as they were before you upped your fuel pressure. youll see more of a performance increase if you install new injectors which are rated to flow more fuel. -
looks sharp! i want more info on the coilover install! i need a suspension that makes me think more rally car and less open seas.yarr matie!
Lets talk about slotted rotors again
nkx replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i thought slotted rotors were also supposed to add more 'bite' because the edge of the slot cut into the brakepad, thus increasing braking ability..?
