1slow_si
Location
Bowie
Vehicles
I Love My Subaru
1slow_si's Achievements
Advanced Member (3/11)
10
Anyone near Maryland want a Loyale?
1slow_si replied to 1slow_si's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No, It's not driveable but it may run since I replaced the fuel pump. I removed the ignition relay with the intention of replacing it and have since lost it so it will need to be towed. -
I am giving up on this project and want it gone. 91 Loyale push button 4wd 5 speed. 190k? Clean condition intermittent starting problem. I have replaced the tires, disty, plugs, coil, fuel pump and battery (die hard gold) any offers over $300 takes it. The tires alone are worth that. I don't have any pics. I -m located in Crofton Md. Anyone interested can call me @ 240-417-7168. I work @ night so if I don't answer, just leave a message. NO BULL************TERS! NO CREDIT! CASH ONLY! BRING YOUR OWN TRAILER AND HELP TO LOAD IT UP! Billy
91 Loyale 2 years and still not running
I don't know what I was thinking. It's been a long time since I worked on the car. It has been sitting in the garage neglected for over a year. Now that you mention it, The ignition system is working fine and I did replace the ign. relay. I hooked a test light to the coil and to the battery and can see it pulse. The problem was once it started it would cut off. It seems like the fuel pump doesn't continue to work after it starts. Would low pressure cause these symptoms? I want to get this thing out of my garage and maybe save some gas money instead of driving my tundra. BTW, no codes. -
Yeah, The fuel filter is brand new. My main questions are, Do you think it sounds like the fuel pump? and Will low fuel pressure cause the ignition system to cut out? How many miles on avg. will an ea82 run before it needs a rebuild? I hate to throw money at a car that won't last after it's fixed. -
I purchased this car from a co-worker for $300 and it would run sometimes and sometimes wouldn't start. I checked the ignition system and it too was working sometimes and sometimes not. I replaced the ECU, the worn distributor, the coil, the little blue box in the kick panel, and checked the fuel pump relay and it was good. Same thing! Sometimes would run and sometimes wouldn't. The last few time that it ran, the fuel pump was making some funny noises while priming and now it quit working all together. Could this problem have been the fuel pump all along? If the fuel pressure is too low, will it cut the ignition system? I drove it once when it decided to run properly and got about a mile from my house and then lost its power and wouldn't idle. I had to keep playing with the throttle to keep it running to limp it home. On the way home I had to go up a big hill and it started pinging and had no power. It felt like it would stall if I tried to give it more gas. Does this sound like the fuel pump to you? I hate to spend $200 to $300 for a new fuel pump on a $300 dollar car with 189k on the clock. Do you think it's worth it? The car itself is pretty clean with no rust, except for a small patch of surface rust on the drivers door where it looks like it had a scratch that was never taken care of. Also, the rear bumper cover is warped due to the previous owner driving it after the exhaust tip broke off and the hot exhaust gas dumped straight into the bumper. Any help would be appreciated. Thanks, Billy
I haven't checked the TPS yet, I tried to start it today and the fuel pump didn't even come on. I ran wires from fuel pump to battery and she fired right up and died. Tried a second time and got the same thing, Third time and she acts like she's flooded.....(no start) When I plug in the green connectors it doesn't do anything. I can hear a solenoid clicking under the hood about once every second and a half? No fuel pump noise and no light. I have already checked the MAF with a meter and got correct values on everything. I'm stumped. It acted like this before, and when I changed out the ECU the fuel pump would prime itself when I turn the key on. Now it's not. The only thing I've done is tried to jump start it with a battery charger set on 55 amps. Could this fry the ECU? The old ECU seemed to work right, until I tried to jump it with a booster pack. Thanks B.
Been there, done that......Anything else?
I'm still trying to start this pos and it wont run right. It will start right up now that I replaced the ecu but immediately shuts off like it's running out of fuel. I tried plugging in the green connectors with the key on and get nothing, but when I turn the key to the on position I can hear it prime itself but doesn't pulsate. If I play with the throttle, I can keep it running and once it warms up it will continue running but at an extremely high rpm. Any more ideas? B.
I finally got my 91 loyale to start after replacing the computer but now it wont idle. As soon as I start it it idles for maybe 2 seconds and dies. If I try to give it gas, it dies. Sometimes I can manipulate the throttle and keep it running until it warms up and then it will idle, but very high. Previously I was told to check the MAF and when I checked it per FSM it tests fine. What could it be? Billy
starts but wont stay running?
I think you guys might have something with the MAF Sensor. I forgot that I wanted to clean it and couldn't find any MAF cleaner, so I used windex. I figure it should be ok since it's mostly alcohol and not a harsh solvent:confused: . Anyhow, The ecu is just giving me 5 short flashes (I assume this is normal) and the fuel pump gets 12v when I turn the key on (Not sure when running) but I don't hear it cycling with either or both connectors plugged in, I just get the solenoids clicking under the hood. Is this normal? BTW, Thanks to everyone for the help and whoever posted the link to the "FULL" FSM PDF. I found a flowchart that walked me through the steps of diagnosing a no start (weak/sometimes no ignition pulse) problem that led me to replacing the ecu and now it kinda runs and my $300. beater is almost ready for the road. Billy -
I checked all of the vacuum lines and found nothing? I didn't see one hooked to the air box? Unless you are talking about the pcv system? It will start everytime but just shuts of like it's running out of fuel. I connected the white connectors and hear a clicking but the fuel pump doesn't cycle, So I ran 2 wires from the battery to the pump and same thing? I put a test light on the neg side of the coil and to ground and can see the pulses when the coil fires. So I have spark and fuel, What can it be? -
I just changed the computer in my 91 loyale and it started right up:banana: but it wont stay running. When it starts the rpm's shoot up to about 2k and then dies. Is this a common problem? Ideas? Thanks
I added a clutch fan and look what it does!
1slow_si replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't understand? The link is of a planetaking off:confused: -
got my new 1980 Brat
1slow_si replied to danrenfroe2016's topic in Historic Subaru Forum: 50's thru 70's
That's funny! I live in Maryland and was just in Irving and saw one just like that near the old Boeing? plant at a garage. I was going to offer to buy it but had no way to get it home. -
Biodiesel is french fry grease, not lard, but vegie oil. In a nutshell, you take used vegie oil and filter it, add lye to neutralize the acidity, add alchol (methanol?) so it doesn't gel. And that's it. It runs cleaner than dino diesel and costs about 17cents per gallon without counting labor. Check out http://www.freedomfuelamerica.com
