bepa
Location
new york city
Interests
Cars-out doors-people
Occupation
U S O
Vehicles
91 SS 4EAT/ 01 ML 55
bepa's Achievements
Advanced Member (3/11)
10
Time For a Cookout!! June 30th is the Date
bepa replied to Bucky92's topic in Meet n' Greet. Your USMB Welcome Center
at first reading about mirror breaking i was like oh yea, be careful. after reading the story I can see it sure be a fun time. I am getting ready for a trip to babysit for granddaughter. her father is going to california for a week. he's in marines and sole caretaker. that said I think I can make this one. it's not to far away and as long as I get off on time I could be there by noon. I now have 2 92 SS's both sticks. they are a blast to drive. well one is running the other is waiting till I get the title. then will fix and enjoy that one on the track. would like to install 4.44's and go after some faster cars. they do not believe what is happening as I go by. the chances are good that I can come. would be driving one of the SS's. will ask a friend to come also. will get back here before then. thanks and safe quick driving, Bepa -
hey saw your post and was wondering how it worked out for you? good I hope, when you get a moment would you let me know. have a motor and trany and was wondering how it worked oput. is it fun to drive. be well and safe dri9ving, Daniel
usually I would jump at a ride. cross country is a trip but at this time I have/am towing a car from maryland down to virigina. try to pull another car back from florida back to ny. all this and still help pay for a ticket from Hawaii for g/daughter used two weekends, one in hospital and next one with family. if I were coming my first stop in ohio and I'm almost there. something like this would have to be during a vacation. atleast a week long. I would not be able to drive as hard as I would like either. what with having to drive it home also. some fun driving always gets me out and about. post some pictures if you would. safe driving and enjoy the snow. Daniel
never can tell if I am getting off or not at work. work a single and end up covering a double. if a date is planned early and I can swing it, I'll be their. need to get out and have a fun drive. is this for street drivers or not. this is my daily driver. would like to keep parts on it for as long as possible. still a fun drive is great! I'll keep after this post to see what is happening.
hey sad4subaru, how far are you from nyc, got a little time on sunday. I am working both days this weekend, mid - 8 a.m. in your case if not to far I would make the trip and we can check these things out this weekend. you cover gas and I will haul a** up to you and we could check out what is wrong. also have sensor's on car to check if you need one. I would use your coil pack on my car. this way we know if they are good. check timing belt then check cam sensor, then crank sensor. if auto zone by you we may even have it running before I leave. holla back. e-mail or sixfoursixtwothreefiveeightthreefivefive.
don't go buying the timing belt yet. you, yes you; yourself can take a timing belt cover off. three blots (10 m.m.) off. then have some one else turn the key. if the belt moves the cams,it's good. it could be a cam shaft sensor or crank shaft sensor. If ECU does not read/sense either one is turning no gas will flow till the ECU does sense it is turning. no rotation, no gas, period. difference between carb and FI engine controls. if not turbo motor, most sensors are the same for several years. go to autozone web site. check number for your car and a junkyard motor and you will find which ones are the same as yours (Motor). them use yard/spare part to check if yours works. but I would first check the timing belt. I have a friend like yours as well. still at times I most double check his work also. I also look for C/B bolts, old trick, leave out a bolt or two out means you are coming back to them. just some thing to look out for. check the timing belt first. this way you know that the motor is turning the cams as well as the crank shaft. once your sure that the cams and crank are turning, next is checking the sensor's. what they do if I get it correctly is use a magnetic signal, sends a pulse when ever the turning crank or cams passes closely by it. it sends a ground signal to the ECU, telling it the cam/crank is moving. with this signal it opens the fuel injector accordly. that is what I think happened to your car. just a quess, but that is what I believe happened to your car. you can check so of this yourself and save your friend and yourself some pain when looking for it. good luck and safe driving. Bepa.
hey man things with get better. subaru's are great cars. when you learn them they are even fun. easy to work on, good for someone just learning how to work on engines. look around for a legacy first generation; 90-94 model years. 2.2 or if you can find a 2.2 turbo. they can be got for a good price. I got one for $940. trany was gone. yes I replaced the trany with a friend and myself. no lift or anything but a jack and jack stands. one evening! since that time I have found 2 SPORT SEDANS for under a 1k. both automatic's. that are running strong. try autotrader and cars.com they are good site's for used cars. they use you zip code and how many miles around you you wish to check. I check every day. also use local used car papers, they are good places to look. anything subaru in the early 1990's is a good bet and can be got cheap if you look around. you should be able to get a good car for under $2000. keep your head up and do not tell the seller how bad you need a car. your looking for a second car. need a back up for when other car is in the shop, girl friend needs a car. anything but that you are in need of a replacement! helps you control the pricing of the first bid. always remember they have a car for sale, but you have the money. If they don't deal with you the way you would like; take your money and leave. money in your pocket does nothing for the saler if you leave with it! oh yes your stuff will be made to fit the car you get. try the legacy because you will not believe the space inside one of these. wagon is even better. look for a touring wagon. this is a turbo wagon, almost as good as a sport sedan, just the space of a wagon. popo do not even give it a second look as you speed by. good on gas. I get 25-26 at about 85 MPH. once even getting to 100 for 15-20 minutes and still getting 25.5 MPG during 600 mile trip. sticks are fun, in a subaru you need to treat them right, they will live a long time. auto's are another story, they must be checked. if you treat them right they go far. do not hammer them. You can drive hard, but they are easy to kill or hurt. if you over heat the motor it is best to change motor and trany fuilds quick. I've had four turbo legacy's, three were auto's. yes I would get them again. only one hard my wallet hard. I drive hard, respond to emergency calls and have family responsibilities. one is special to me, my granddaughter, father in marines. at times we drive thru several states during the night, deliver her and G/M to air port or to where we can see him for a minute , hour or a few days. my four subaru's have let me down only once due to a bad repair. bolt broke after a timing belt replacement. I do almost all of my own repairs now. saved a bit of money and learned how to repair subaru's. not to many suprises that way either. good luck, keep the faith and a good subaru is out there for you if you look. Be Well, bepa. (Daniel). let me know how it goes. wish I was more able to assist you. not on west coast, in new york. your be home when your near me, yet if I could assist hit me up. be safe and good luck to you. D
CT Cookout..Who wants one?
would like to attend. work first shift that day. thing is we are down 4 guys at work. if I get relief as posted I can leave and get their in a few hours (less if I do not get stopped). will keep in touch. need to get to one of these subaru parties and hang out. -
frederick md cookout, version 2
bepa replied to subyrally's topic in Meet n' Greet. Your USMB Welcome Center
working weekends; but will request that weekend, this is close enough I could try to make it. nice road trip if I get the time off. have to get correct location. map quest here I come. be well, Daniel. -
North East Offroad Subi Meet: July 15th, @ Paragon
bepa replied to Andyjo's topic in Meet n' Greet. Your USMB Welcome Center
working weekends this month. trip was to far for me to get there in time. only car for trip is 91 SS. not the best car for trailing. still the first level would be doable. will keep eye on post for another event. be well and safe trailing. -
New Clutch
bepa replied to cannonball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
just asking; when I had a clutch put in my first turbo stick, with the hyd clutch the pedal was at the top. was told by most it could not be adjusted. it could and I did lower the take up point. ask if they could adjust it for you. price is something that goes with the service and how they back up the service. if you understand what I am saying. guy I know sales cars. he will tell you as is, yet if you drive away and came back a few days later, he would still see to it that it was fixed. he has many repete buyers and word of month sales more cars then ads could ever is the way he see's it. all and all the price was fair for sure. and as you said you have been doing business for a while. enjoy the subaru and a summer of fun driving. a stick in a subaru is a great combination. be well, be safe and enjoy your ride.
